Vray+Sketchup: texture on smooth surface
Hallo!
I'm using vray for sketch-up
I try a lot of time to use texture on smooth surface, but I have always the same problem.
You can see the file atthach: the texture ate not tile...I have read a lot of post, but I can find a solution... May be is a stupid problem, but I can't solve
Thanks for help!
Hey,
Have a look at the manual here http://software.asgvis.com/index.php?option=com_docman&task=cat_view&gid=443&Itemid=536
On page 50 they show how to use texture mapping. One addition is for a smooth surface you have to turn the hidden geometry on so you cna adjust the texture as discribed in the manual.
Hope it helps
@tobobo said:
Hey,
Hope it helpsThanks for your replay!!
Yes, I have read the manual, but it can't solve...
In the mean time I have find a good solution here:
http://forums.sketchucation.com/viewtopic.php?f=18&t=10762&hilit=texturing+organicThis is my resut: I need to do better... I have to try
http://forums.sketchucation.com/viewtopic.php?f=18&t=10762&hilit=texturing+organicThats exactly what i was trying (although poorly) to explain.
