    Materials again
    6 Posts 3 Posters 396 Views 3 Watching
    • K Offline
      kiesewetter
      me again...
      i don't know why, but the attribut "ablauf", "material" always receives a new value, even if the face's material is included in the array called invalid_material. i'll post the code, because i realy don't know how to fix it.
      ents.each{|e|
                if e.typename == "Face"
                   start = e.get_attribute "ablauf", "baubeginn"
                   ende = e.get_attribute "ablauf", "bauende"
                   if (e.material)
                     invalid_materials = ['bau_mat', 'fertig_mat', 'inplanung']
                     unless invalid_materials.include?( e.material.name )
                       mat_vorher = e.material.name
                       e.set_attribute("ablauf", "material", mat_vorher)
                if @woche.to_i >= start.to_i && @woche.to_i < ende.to_i
                  e.material = bau_mat
                if @woche.to_i >= ende.to_i
                  e.material =fertig_mat
                if @woche.to_i < start.to_i
                  e.material = inplanung
          #now the code that reloads the material
          def mat_back
             mod = Sketchup.active_model
             ents = mod.entities
             mats = mod.materials
             default_mat = mats.add "standardwert"
             default_mat.color = [50,250,50]
             ents.each{|e|
                          if (e.get_attribute "ablauf", "material")
                            mat_temp=e.get_attribute "ablauf", "material"
                            e.material=mats[mat_temp]
                          else
                            e.material=default_mat
        To check the materials' name make the line
        p mat_vorher = e.material.name
        Then it will print the name of the material in the [opened] Ruby Console to compare with your invalid_materials list...
        Looks like they don't match ?
        • K Offline
          kiesewetter
          it was my mistake. the materials were declared in a tool as a local variable. every time the tool was invoken, the materials werde declared. so to the materials name was a number added, because the material already existed in the materials container. when you only once invoke the tool everything is fine. one more an it didn't work.
          is it possible to declare a material as a constant or to declare it with an "@" in a class to avoid that?
            Why not just check if the material exists?
              For example:
              if mats["standardwert"]
                default_mat = mats["standardwert"]
              else
                default_mat = mats.add("standardwert")
              • K Offline
                kiesewetter
                it works. thanks a lot, once more πŸ˜„
                tommorow t'll try to declare the material in the constructor of the class anyway, to avoid putting all the trash in the memory.
                bye.
                tim
