    Radial Bending changes colors
    2 Posts 2 Posters 596 Views 2 Watching
    • hellnbakH Offline
      hellnbak
      When I used Radial Bending on this object, it did the bending just fine, but the colors changed. As you can see, the lower half of the front face is a different shade than the rest of it. I've tried repainting, it happens no matter what color I use. Any suggestions?
      • jeff hammondJ Offline
        jeff hammond
        the geometry is jacked..
        this color shift often happens after strange intersections or other 'unorthodox' transformations to the geometry..
        here's a quick example caused by a boolean subtraction.. the affected face consists of weirdly positioned edges at the point of intersection..
        it can also happen from softening some of but not all of a group of lines defining the adjacent edge between two faces..
        solution: pretty much, it needs cleaner geometry..
        meh.skp
        dotdotdot
