    Unzipping archive from Ruby (Mac and Windows)
    55 Posts 11 Posters 13.5k Views 11 Watching
    • fredo6F
      fredo6
      I am not sure this has not been covered elsewhere in the forum, but here is what I found for unzipping archives from Ruby.
      On Mac, it seems that there is a unzipcommand embedded.
      Here is a simple code snippet
      #Extract all files and sub-folders from an archive file to a destination folder
      #Status is returned true if successful, false otherwise
      def unzip_on_mac(archive, destination_folder)
        return false unless FileTest.exist?(archive)
        status = system "unzip -o \"#{archive}/*\" -d \"#{destination_folder}\""
      A few notes
      • the internal double quotes are needed when archive or folder names include spaces
      • the flag -o is required to overwrite existing files if any
      • the operation is quite fast
      On Windows, it is more complex. It seems that all versions of Windows include a built-in facility for zipping and unzipping, but I did not find a way to invoke it from the command line. Also, the command Extract seems to work only for .cab files, not for .zip files. So you have to rely on an external zip program.
      1. if Winzip is installed, then its location should be
        zip_program= "C:/Program Files/Winzip/Winzip32" (or 'Program Files (x86)')
        Then the command to execute is simple
      def unzip_with_winzip(archive, destination_folder)
        system "#{zip_program} -min -e -o \"#{archive}\" \"#{destination_folder}\""
      Note that:
      • -min is to avoid the nasty black screen popup
      • -e is just form extracting
      • -o is for overwriting all files if already present at destination
      1. we could similarly find typical location and command line parameters for other popular unzip programs(like 7zip or wintar)
      2. If none of them are present or can be located, then it is possible to download a small unzip.exe, which is just the part for unzipping of winzip (it is free and distributable). Its interest is that it is standalone (no dll dependency). It can be put in a SU plugin subfolder that is controlled and known.
        rename it unzip.exe
        in that case, assuming you put the path of the exe in variable zip_program, the command is
      def unzip_with_unzip(archive, destination_folder)
        system "#{zip_program} \"#{archive}\" -d \"#{destination_folder}\""
      Note: this unzip program can be downloaded by users with a text extension, and then it is possible to rename it from Ruby, via File.rename
      Finally, on a related subject, I found that if urlpath contains the shortcut to a file attachment on Sketchucation (obtained via copy shortcut), then you can easily invoke the dialog box for download:
        urlpath = "http://forums.sketchucation.com/download/file.php?id=58102"
        wdlg = UI;;WebDialog.new
        wdlg.set_url urlpath
        wdlg.show
      The issue there is that you have no idea where the user has decided to put the file, or whether s/he has chosen to 'run' the file instead of saving.
      So I guess we'll need good ideas on how to download a remote file from the web, whether from Ruby or via a program launchable from the command line, without the many hassles of installing big side libraries (like net/http).
      Fredo
      • thomthomT
        If the user has install
        Webdialog - use XMLHttpRequest object to download the file. Though, if you try to download from SCF you need to be logged in, don't you?
        • J
          Jim
          TBD's Dezip works great on SketchUp on Windows. I use it in a prototype plugin installer on my machine.
          http://github.com/TBD/OpenSUP
          • tbdT
            tbd
            by default, on Mac, you cannot view .zip files as directories 😞
            and searching for installed programs to unzip is ugly and hard to debug/support.
            a port of Dezip to Mac would be nice to have πŸ’š
            SketchUp Ruby Consultant | Podium 1.x developer
            http://plugins.ro
            • jeff hammondJ
              jeff hammond
              not sure if this matters or not on what you're hoping to accomplish but just a heads up..
              when unarchiving on mac, there will be an extra folder..
              let's say i have a su plugin which consists of MyRuby.rb & an accompanying folder named MyRuby
              i compress those into a zip called Archive.zip
              when i unzip that, the structure will be:
              Archive (folder)
              MyRuby.rb
              MyRuby
              i think this is why many people end up with suPlugin install problems on mac because the instructions are always 'unzip in the plugin folder' which, of course, won't work due to that extra folder.
              [which can get more confusing when the .zip is named the same thing as the accompanying folder as it often is because you end up with two folders sharing the same name]
              dotdotdot
              • T
                tfdesign
                I should think so too! How many PC's get infected by zips opening without permission? My sister has already had to reinstall her Windows OS because of similar mishaps (she is one of so many who could really know more about what they are doing!)
                Really? Perhaps I didn't understand you? I just right click on a zipped download and a contextual menu appears with a list of options to choose from (including the built-in dearchiving software, which is activated by double clicking a zipped file anyway). I hardly call that ugly. πŸ˜•
                As for a decent zip utility, I thoroughly recommend Betterzip
                http://macitbetter.com/
                My book "Let's SketchUp!" Download from here
                • thomthomT
                  None. Opening up a zip is like opening up a folder - you don't execute any code.
                  We're talking about unzipping via SketchUp Ruby in order to make installing and updating plugins easier. What he referred to as ugly was relying and detecting third party zipping software to do so.
                  • fredo6F
                    fredo6
                    Tom,
                    Very good remark, full of good sense.
                    Do you know if there is a way to specify the login on the flyin a request to a page (like http://forums.sketchucation.com/viewtopic.php?f=323&t=29230&hilit=plugin#p254673)?
                    fredo
                    • thomthomT
                      You could maybe send a POST message with XMLHttpRequest with login information to SCF's login page. ...though I'm not sure if doing that via XMLHttpRequest will give you a persistent session...
                      • T
                        tfdesign
                        That's not what I meant, but nevermind. I understand the context now πŸ˜„
                        Okay πŸ˜„ It is different, but then I hardly use PC's any more, so I'm just used to the Mac way. πŸ˜„
                        • fredo6F
                          fredo6
                          Would anybody know:
                          1. either the inline syntax in the request (if this is supported), like
                            http://forums.sketchucation.com/viewtopic.php?f=323&t=29230&hilit=plugin#p254673&user=Fredo6&pwd=mypwd
                          2. or the post syntax for the SCF login page?
                          Fredo
                          • Dan RathbunD
                            Dan Rathbun
                            What URL do you see if you hover over the SCF Login link.
                            (I have autologin set in my SCF cookie so I never go thru the login.)
                            I'm not here much anymore.
                            • jeff hammondJ
                              jeff hammond
                              the log in page at scf is this url:
                              http://forums.sketchucation.com/ucp.php?mode=login
                              dotdotdot
                              • thomthomT
                                It would not be part of the URL - as that would be a GET.
                                The HTML source for the login:
                                <form method="post" action="./ucp.php?mode=login" class="headerspace" style="border;dashed 2px #ca0016;margin;auto auto 10px auto;padding;0 10px 10px 10px;width;97%;">
                                	<p style="font-weight;bold;margin;11px 0 0 0;float;right;padding;3px 5px;"><img src="http://sketchucation.com/forums/styles/prosilver/imageset/help.gif" height="22" width="23" alt="" style="margin-right;5px;" /><a href="http://www.sketchucation.com/scf-contact-page2/" style="font-size;1.1em;">Problems with registering / logging in?</a></p>
                                	<h3><a href="./ucp.php?mode=login">Login</a>&nbsp; &bull; &nbsp;<a href="./ucp.php?mode=register">Register</a></h3>
                                		<fieldset class="quick-login">
                                			<label for="username">Username;</label>&nbsp;<input type="text" name="username" id="username" size="10" class="inputbox" title="Username" />
                                			<label for="password">Password;</label>&nbsp;<input type="password" name="password" id="password" size="10" class="inputbox" title="Password" />
                                				| <label for="autologin">Log me on automatically each visit <input type="checkbox" name="autologin" id="autologin" /></label>
                                			<input type="submit" name="login" value="Login" class="button2" />
                                		</fieldset>
                                	</form>
                                The important stuff here is:
                                This means the POST request must be made to http ://forums.sketchucation.com/ucp.php?mode=login
                                and you need to set the arguments, "username", "password" and quite possible "login" (login as very often the website software checks the value of the submit button to detect if a form has been used - but that depends on the software)
                                • Dan RathbunD
                                  Dan Rathbun
                                  The form fieldnames on the SCF login page are:
                                  username
                                  password
                                  But there is also a "sid" (security ID) involved. The Admins may not want spambots being able to auto login. Ask Coen.
                                  • thomthomT
                                    HTML forms' submit buttons doesn't display the target URL info. One has to look at the source code.
                                    • Dan RathbunD
                                      Dan Rathbun
                                      I know (and I did,) it was a hint. But you cut and pasted the code before I could.
                                      • tbdT
                                        tbd
                                        Fredo6: what do you want to do with SCF download ? maybe we can create a backend that suits your needs better thank going through forum software
                                        http://plugins.ro
                                        • fredo6F
                                          fredo6
                                          I am investiogating 2 things:
                                          1) Scan the SCF page where a plugin is.
                                          That's sorted out with WebDialog and this will allow to check the current version and date of the plugin. This of course requires some strict syntax convention, for instance in the title, so that it is easy and discriminant to parse the info.
                                          At least, this will tell whether the plugin is up to date or not
                                          2) Download the file (zip or rb) to the local disk in the right place.
                                          I assume that with some syntax convention, it will be possible to locate the URL address of the file.
                                          For this however, this requires that the user is logged in to SCF (as ThomThom judiciously noticed).
                                          Then, if the file URL is obtained, I can:
                                          • either invoke the download dialog box via WebDialog
                                          • or find out another way to download it
                                            Not sure there is an easy way
                                          Fred
                                          • fredo6F
                                            fredo6
                                            I was WRONG about the Mac unzipping as folder.
                                            But I found out that there is an embedded unzip command, which can be invoked via the Ruby system call system.
                                            see main post for details
                                            I have no clue if this is present on all Macs.
                                            Fredo
                                            PS: just taking the opportunity that I have a Mac at hand to make a few tests about this question of plugin installation, as I usually prefer to release scripts for both environments and users.
                                            • 1 / 3
