    Get group location over Ruby Script
    10 Posts 5 Posters 3.3k Views 5 Watching
    • O Offline
      Ossi01
      Hello everybody,
      can somebody explain me, how i get the location of a group(In Sketchup.active_model) over a ruby script ? Currently, i get only the local position of the entities in the group(groups have a own axis of abscissas), but i need the global position. I hope, you-all understand my problem
      Cu
      Ossi01
        Is the group in the active context? ( model.active_entities ? )
        How are you obtaining the group?
        • O Offline
          Ossi01
          @ thomthom : Yes, the group is in model.active_entites and i obtaining the group. This isn't my Problem. But i get over Sketchup.active_model.active_entities[0].entities[1].end.position or Sketchup.active_model.active_entities[0].entities[1].start.position the local position of a edge(Start- and End-Vertex) in the group , not the global position in the whole model ! But i need the global position
            Try tr=group.transformation to get the group's current position and then when you get the contents points transform! them by 'tr' - e.g. pt.transform!(tr)
            If the group is not within the model.entities (as in group.parent != model) you need to recursively apply the parent's parent's transformations until it is etc... using a while parent != model ... end loop ?
              Ok - assume you have an edge in group in the current context - the group is selected
              model = Sketchup.active_model
              sel = model.selection
              group = sel[0]
              edge = group.entities[0] # Assuming there is only one edge in the group
              global_start = edge.start.position.transform( group.transformation )
              Not that when you open a group or component for editing, the co-ordinates you get in active_entities are the global ones.
                As long as the group is within model.active_entities one only need to apply the group's transformation.
                And you can't go backwards by parent as you traverse definitions instead if instances.
                • O Offline
                  Ossi01
                  big thanks @ TIG and thomthom. It works πŸ˜‰!!
                  • honoluludesktopH Offline
                    honoluludesktop
                    Isn't this ("the location of a group") what Ossi01's asking? The example uses selection to Id a group, then gets its transformation, then its origin based on its location from the model's origin.
                    my_selection = model.selection
                    my_selection.each do |ent|
                      if ent.is_a? Sketchup;;Group
                         t=ent.transformation
                         puts t.origin.to_a
                      When you get the position of a point [ pt] in a group.entities [or definition's] it is relative to where it was 'made' i.e. for a model it's bounds.min is typically taken as the model.origin. So the point is returned relative to the group's coordinate system not the model's. You can apply the tr=group.transformation to that point pt.transform!(tr) and it is now given in the model's coordinate system... If groups are nested then the transformation of each parent back to the model level has to be taken into consideration...
                      • H Offline
                        HerveRenault
                        Thank you very much for the tip !
