    Script for Floor Area Calculation Tag/text
    3 Posts 2 Posters 682 Views 2 Watching
    • 3 Offline
      3dsketchupper
      I've been looking for a script that can add text/tag to a spicific AREA OF geometry. I saw that script before but just forgot the name of script.
      Thanks for your help.
        If you place a piece of text on a face its text is the area in current units - not much use if you work in mm and want sqm!
        Find my 'Area Formatter' script [ http://forums.sketchucation.com/viewtopic.php?p=12808#p12808 ]. That will take a piece of selected text describing an area and reformat it to whatever units you want using a dialog...
        It's not 'dynamic' - I have a half-baked AreaTag tool that would add a text tag to a face in whatever format you choose and also update as the face's area changed too - but that's on hold with several other tools - my uni teaching commitments are getting in the way!
        • 3 Offline
          3dsketchupper
          Thanks TIG i'll check it out
