    Get_datfile_info
    2 Posts 2 Posters 282 Views 2 Watching
    • Al HartA
      Al Hart
      This is clear as mud.
      Does anyone know what Sketchup.dat is or what Sketchup.get_datfile_info does
      Sketchup.get_datfile_infoSketchUp 6.0+
      The get_datfile_info method is used to retrieve the value for the given key from Sketchup.dat.
      If the key is not found, default_value is returned.
      Arguments:
      key
          The key whose value you want to retrieve.
      default_value
          The default value you want returned if key is not available.
      Returns:
      value
          a string value if successful.
       value = Sketchup.get_datfile_info(key, default_value)
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
      • thomthomT
        The file seem to be a config file of SU.
        // NOTE TO USERS: Making modifications to this file is not recommended as it will be overwritten
        // each time an upgrade is installed.
        I don't see much useful info in it for us...
        Possibly it could be used to brand SU - but as the file warns - it'll be overwritten upon SU updates...
