    Groups?? Need Some Help
    4 Posts 3 Posters 247 Views 3 Watching
      c0nfused2
      I try and build my model in groups, so its easier to work it and hide/lock and such. The only problem I have is it seems like when I have one group which is lined up to another for instance a wall and a floor, they dont line up on each other, it seems like there might be an overlap of the two groups, is there a way around this? Thanks
        Can you post a screenshot or a sample model?
          c0nfused2
          It doesnt really show up on images, just when modeling, I jsut dont know if it interfers with rendering,
          i.e. small cracks that light will seep through
          • mitcorbM Offline
            mitcorb
            This may not apply to your specific issue, but:
            If you create abutting groups like you suggest, then modify the groups in any way, you have to be careful that the modifications you make do not deform the edges/faces where it touches/ matches the adjacent group.
