    Interrogating each group to find Cylinders & Cubes
    8 Posts 4 Posters 930 Views 4 Watching
    • N Offline
      nkclarke
      I'm new to script writing but I'm trying to write a Ruby script to complete a task I've been given at work. I have a skp file containing only separate groups (several hundred). Each group consists of EITHER a CYLINDER or a CUBOID. I'm trying to come up with a script that examines each group in turn and can judge whether the shape is a cylinder or a cuboid. If the shape turns out to be a cylinder, I need to extract the co-ordinates of the face centre, the diameter of the circle and the length of the cylinder. If the group meets the criteria of a cuboid, I need the co-ords of the lower corner/vertex and the dimensions of the cuboid.
      Also, I need to be able to export the above information into a text file.
      Any tips or help would be gratefully appreciated. Or, a view on the achievability of what I'm trying to do would also be useful.
        If you have groups then you can of course give them names like group.name='cuboid' and group.name='cylinder' - then NO tests are needed just compare the names !!! πŸ˜’
        If that simple trick won't do...
        To see if a 'face' belongs to a cuboid test it for number of edges and connected faces...
        face=nil
        group.entities.each{|e|
          if e.class==Sketchup;;Face
            face=e
            break
        not_cuboid=false
        not_cuboid=true if face.edges.length!=4
        faces=[]; face.all_connected.each{|e|faces << e if e.class==Sketchup;;Face}
        not_cuboid=true if faces.length!=6
        faces.each{|f|
          if f.edges.length!=4
            not_cuboid=true
            break
        'face' is a cuboid 'if not not_cuboid'
        This doesn't trap a cylinder made with 4 sided circles which would look 'cuboid' too...
        If the cylinder is truly made from a 'circle' then you can test further for 'curve' and 'smooth' edges
        faces.each{|f|
          f.edges.each{|e|
            if e.curve and e.curve.class==Sketchup;;ArcCurve
            if e.smooth?
              not_cuboid=true
              break
          break if not_cuboid
        It also doesn't trap for non-right-angled corner cuboids... to check for that
        faces.each{|f|
          verts=f.vertices
          vertsp=verts+verts[0]+verts[1]
          (verts.length).each{|i|
            veca=vertsp[i+1].vector_to(vertsp[i])
            vecb=vertsp[i+1].vector_to(vertsp[i+2])
            ang=veca.angle_between(vecb)
            if ang!=90.degrees
              not_cuboid=true
              break
        If it's a cuboid then get bb=group.bounds and then
        x=bb.min.x y=bb.min.y z=bb.min.z
        If it's a cylinder find the 'circle' face
        circle=nil
        len=nil
          if e.class==Sketchup;;Edge
            if e.curve and e.curve.class==ArcCurve
              circle=e
              len=e.length
              break
        center=circle.center
        diameter=circle.radius*2
        height=nil
            if not e.curve
              height=e
              break
        You now have center, diameter and height for the cylinder... πŸ€“
        • N Offline
          nkclarke
          Thank you so much for that. You went to a lot of trouble for me and I appreciate it. I think it'll take me some time to get my head around it but for me it's a good introduction to Ruby.
          • N Offline
            nkclarke
            Once I've been able to extract all of the data I need during my interrogation of all the groups, is it possible to export these variables into a separate text file? Or does the Ruby environment within SketchUp prefer the user to stay within SketchUp?
              It's easy enough to export data to a file.
              Find ComponentReporter++.rb for an example...
              Export and Import are relatively straightforward, it how you manipulate the data before/afterwards that's more tricky...
              • P Offline
                peterjohnson84
                I am also working on this problem and though I follow the logic behind the code you wrote - I am struggling to implement it.
                How do you get sketchup to recognise the group.(...) method? i.e. stop it returning the error:
                undefined local variable or method `group' for JF::WebConsole:Module
                when I type:
                    face=nil
                        face=e
                        break
                    not_cuboid=false
                    faces.each{|f|
                        not_cuboid=true
                        break
                Its as if sketchup doesn't know what group I'm referring to - doesn't know what 'group' even is. After searching I have noticed some talk about 'active_entities' and suspect the answer may be invlved with this somehow.
                Apologies if this sounds like nonsense - I think I'm missing something big, but can't work out what it is.
                Cheers, Pete
                  Because it doesn't. group is just another variable - you need to make a it reference the group you want.
                  For instance, if you want group to reference the selected object:
                  group = Sketchup.active_model.selection[0]
                  • P Offline
                    peterjohnson84
                    That's the badger! Though as is the way with these things, it seems so simple once I know the solution.
                    Thankyou very much anyway...that has helped me a great deal.
