    Draw on sandboxsurface
    9 Posts 6 Posters 947 Views 6 Watching
    • Y Offline
      yourgod
      Hi.
      I'm working on a ground/area, where I want to place a house.
      In that context, I would like to create roads on the area.
      I have drawen contourlines and converted to sandbox.
      Now i would like to draw lines, that will be the road on the surface.
      But when I do that, the line is going trough the surface.
      What can I do?
      Update:
      Now I have trying the new tool.. But I can't get it to work as I want it.
      I draw the roads with the "draw lines ... on surface tool", but how do I paint it with the materialstool?
      As you can see, I have drawed a square on the surface, but the innerarea is not marked..
        Tools on Surface by Fredo 6 ?
        • Y Offline
          yourgod
          great..
          how do I install it?
            remus
            theres instructions on how to install it at the bottom of the first post.
            • srxS Offline
              srx
              You can draw it on a plane and then project using sandbox/drape tool.
              www.saurus.rs
              • Y Offline
                yourgod
                hmm I have tried,
                but now SU says
                "Error Loading File ZLoader__OnSurface.rb
                No such file to load -- LibFredo6.rb
                • W Offline
                  wyatt
                  The Quickcard pdf documentation in the same post where you downloaded the script shows you where to install everything. Libfredo6.rb needs to be downloaded separately: http://forums.sketchucation.com/viewtopic.php?f=323&t=17947&hilit=plugin.
                  • Y Offline
                    yourgod
                    thx for the help..
                    and not to myself..
                    remember to read the manual.. 😄
                    • Chris FullmerC Offline
                      For something like that I would prefer to draw the outlines on a flat plane directly above the terrain, then drape the outlines onto the terrain. It works very nicely normally.
                      All my Plugins I've written
