    [REQUEST] Drop on a specified surface
    4 Posts 3 Posters 517 Views 3 Watching
    • P Offline
      Panga
      Hi all,
      This is a little request in order to complete the existing Drop plugin.
      Issues of this plugin are well-known :
      • drop on hidden entities
      • interferences between dropped components
      Is there a way to modify the Drop plugin to add an option to Drop on a specified surface, in order that the plugin ignores all the other entities ?
      If someone already know a workaround to avoid thoses issues, I'm Listening !
      Thanks in advance.
        Raytracer ignores hidden entities: http://forums.sketchucation.com/viewtopic.php?f=323&t=30509
        I was thinking of doing a target surface thing - but the current version works well when you just hide the other geometry.
        (Note that SU8 has a problem with it's raytracing method - so all the plugins that does this might act a little unpredictable in some cases.)
        • P Offline
          Panga
          Hi Thomthom,
          Did not see the new features of your Raytracer plugin...or I missed them since the beginning 😳
          I'll give it a try, thanks !!
          Cheers.
          • shuraS Offline
            shura
            How about Chris Fullmers Component onto Face plugin?
            It does not exactly "drop" a component, but it places a copy of a component on the center of each selected face.
            edit: on hidden faces it works as well!
