    Bug on UNDO button in SU8
    8 Posts 5 Posters 1.3k Views 5 Watching
      alexdobras
      i have just begin working with SU8 and i already found a bug, that the UNDO button only works one time. If i press again, it will not bring me my model one step back.
      Do you have the same problem? what is wrong?
        I have never had any issues with the undo function. Make sure however that the main SU window is the active window (not any of the dialog windows like material or components).
        Also, what keyboard layout do you use? On my Hungarian window, the Y and Z are swapped and sometimes I use this layout but sometimes I switch to US where I of course press the Ctrl+Z in f. vain to go back. πŸ˜’
          Some times Undo will shift the focus from SU's main window to one of ti's tool windows - it some times does that after using of the the controls in the windows. Like material editor - if you edit the sliders or textboxes it'll trap the focus when you undo. Very annoying thing.
            alexdobras
            guys, i am undo-ing correctly , but it just doesn't work, more then one step it doesn't undo. I don't know what is wrong 😐
            • AnssiA Offline
              Anssi
              This is nothing new. The bug was already in version 3. The number of undos possible before the SU window loses its focus seems to vary. Clicking on the titlebar enables undo again, for a time.
              Anssi
                alexdobras
                i have installed su, and now it works. Thanks to everyone for the support!
                • KrisidiousK Offline
                  Krisidious
                  re-installed I assume? version 8 and not stepped back to 7?
                  By: Kristoff Rand
                    alexdobras
                    yeah πŸ˜„ reinstall. i donwloaded it from sketchup.google.com to be sure
