View hidden Edges ?
Hi all,
I need to display "hidden Edges" on surfaces in SKP. It's possible when using SandBox (surely because edges can be turned), but seems impossible on regular (non SB) other surfaces. It's quiet important to produce better meshes to see those elements.
Context of use : Import SKP models in 3dsMax, so I need to see hidden edges to ensure that geometries are best organized as possible.(See ATT.)
Anybody know a way (or a plugins) to display that ? If "no", I'll push this to "Dev Request".
Thx.BillBaroude
View -> Hidden Geometry -
Oh- you mean the triangulated mesh...
Think TIG has a plugin to do that.
If you just want to inspect them, without converting your SU model, then you can use this plugin: http://forums.sketchucation.com/viewtopic.php?f=323&t=21472
When installed:
Plugins->Probes->UVs
Then use F2 to toggle PolygonMesh on/off -
Hi ThomThom,
Thanks for this cooool plug. The one I need is simplest, but I will deduce a smaller one from yours.
Thanks for your help, and overall all those nice tools you've made.
Register LoginAdvertisement
