    Frank Wright Chair
    23 Posts 7 Posters 3.2k Views 7 Watching
    • troyhomeT Offline
      troyhome
      Looking through the Historic American Building Survey online I found some plans for this chair from the Robie House, 1909 by Frank Lloyd Wright. I assigned it as a model to build for my SketchUp students, then set about to modeling it myself. I found that the plans, sections, and elevations were at odds with each other so ended up just making my best guess. I rendered it in Thea with no pp at all. I need to use a better wood texture: i'm going to try one of the Thea materials next.
      IOviz.com
      SU Pro 2024 PC
        jsteacy
        Can you do a render of the whole chair? I'd like to see the whole thing.
        • DanielD Offline
          Daniel
          So, Troy, you model a Robie House chair, but not the house that goes with it? How lazy can one get?! So far looks great (despite the bare setting).
          My avatar is an anachronism.
          • troyhomeT Offline
            troyhome
            who says i haven't? πŸ˜„
            okay i admit i haven't....
            utter laziness has caught up with me.
            For now here is the overall view. and the .skp- enjoy
            chair done.skp
            IOviz.com
            SU Pro 2024 PC
            • massimoM Offline
              massimo Moderator
              Nice model Troy πŸ‘
              Here is a quick Thea render... πŸ˜„
              • troyhomeT Offline
                troyhome
                I like the render, Massimo. I used a CRF and white balance that made mine look very warm. It's nice to see the unadulterated colors πŸ˜„
                IOviz.com
                SU Pro 2024 PC
                • massimoM Offline
                  massimo Moderator
                  Well, I've changed all the materials. πŸ˜‰
                  • troyhomeT Offline
                    troyhome
                    are you able to share them? they look great!
                    IOviz.com
                    SU Pro 2024 PC
                    • troyhomeT Offline
                      troyhome
                      Here's another overall render
                      IOviz.com
                      SU Pro 2024 PC
                        Nice looking model and renders. My brother and I were discussing that very chair. He's seen the original which is made of cherry and is apparently very rough with screw heads sticking out all over the place. The backrest would be a difficult thing. 1/2" thick and unsupported over most of its length. It would cup like a soup bowl unless it was quarter sawn but quarter sawn cherry isn't very pretty.
                        Thanks for link, too.
                        • massimoM Offline
                          massimo Moderator
                          Sure. πŸ˜„
                          The wood...
                          diffuse map
                          normal map
                          specular map
                          • massimoM Offline
                            massimo Moderator
                            ...and the leather.
                            For the render was used a quite articulated material with scratches made with two different diffuse textures and some layer. Anyway here you have the "base" mat I've made with Pixplant. It's half size in resolution.
                            diffuse map
                            normal map
                            specular map
                              jsteacy
                              Troyhome, thanks for posting the model, it looks great. Especially the render of the whole model πŸ˜‰
                              Massimo, the render is awesome and the posting the materials, wow! thank you! Give you give a little insight into your render? I'm learning thea and I'd love to be able to do similar furniture renders like this.
                              • troyhomeT Offline
                                troyhome
                                Thank you, Massimo, for sharing these!!
                                here's a little pp i did in a cute program called Toycamera Analogcolor.
                                IOviz.com
                                SU Pro 2024 PC
                                • troyhomeT Offline
                                  troyhome
                                  I have never seen the original- how funny that it is so roughed up. I can't imagine the backrest would hold up to much; FLW was moving from architecture for people in a direction that has since taken many architects to a place where architecture itself is the formal end.
                                  Thanks for looking πŸ˜„
                                  IOviz.com
                                  SU Pro 2024 PC
                                  • N Offline
                                    notareal
                                    Nice model. I like this Toycamera mood. Wonder if it's available for win (did not find it)...
                                    • troyhomeT Offline
                                      troyhome
                                      See- you model something and it teaches you more than you could have anticipated! Thanks for all the FLW lore and rendering insights πŸ˜„
                                      IOviz.com
                                      SU Pro 2024 PC
                                      • massimoM Offline
                                        massimo Moderator
                                        Nothing special jsteacy. I've used the screen that comes with Troy's model, just adjusted a bit the chair's position. In this case was used only an HDRI called Dining room of the Ennis-Brown House rotated and tuned a bit in intensity. Rendered with TR1.
                                        P.S. Btw, as you probably know, the Ennis-Brown House is by Frank Lloyd Wright!!! β˜€ πŸ˜†
                                          jsteacy
                                          Massimo, thanks for the insight, as I am an aspiring renderer I wanted to see if I could create a similar image to yours. I hope you don't take it the wrong way. Then I took it a step farther and wanted to create a metallic version of the chair. It doesn't look as metallic as I was hoping but I like it either way. I used the arctic HDRi from that link you posted. Both rendered with Thea.
                                          Troyhome, I agree with you, I didn't even model the chair and I've learned a few things.
                                          • massimoM Offline
                                            massimo Moderator
                                            I prefer the first. πŸ‘
                                            • 1 / 2
