    [Question-difficulty 4/5] Group.transform!
    3 Posts 2 Posters 467 Views 2 Watching
      rvs1977
      Hi all.
      This one I have messed around with, for more than a week now, and is at the point to give up 😳
      My task is to make a tool that rotate a group in the direction of the mousepointer. It has turned out to be a difficult task because, it doesn't seems to be a way of keeping track of the group direction.
      The problem using t= Geom::Transformation.rotation (point, Z_AXIS, delta_angle) and group.transform! t )is the delta_angle. Using this method it adds the angle to the previous angle.
      This is what I have tried: (runable from the RCE)
      class YV_tool
        def initialize
          @mod = Sketchup.active_model
          @ent = @mod.entities
          @state = 0
          inches = 1
          @mm = inches.to_mm
           @pts = []
           @pts[0] = [0,0,0]
           @pts[1] = [108/@mm,0,0]
           @pts[2] = [108/@mm,224/@mm,0]
           @pts[3] = [0,224/@mm,0]
        end # initialize
        def activate
        def onMouseMove(flags, x, y, view)
           ip = Sketchup;;InputPoint.new
           ip.pick view, x,y
           ip = ip.position
           if (@state == 0) # Create Wall_group
            @yv_group = @ent.add_group
            yv_face = @yv_group.entities.add_face @pts
            yv_face.pushpull -10
            wall_edge = @yv_group.entities.add_line ([0,0,0], [1000/@mm,0,0])
            @yv_group_vector = wall_edge.line
            point = Geom;;Point3d.new ip
            new_transform = Geom;;Transformation.new point
            @yv_group.transformation = new_transform
            @state = 1
          if (@state == 1) # group follow mousemove
            Sketchup.status_text = "@state = 1 ; Inputpoint; ", ip, "@yv_group_vector; ", @yv_group_vector
            new_transform = Geom;;Transformation.new (point)
          if (@state == 2) # onLMouseButton place group in choosen position
            Sketchup.status_text = "@state = 2 ; Inputpoint; ", ip
            @ip1 = ip
            @vec1 = Geom;;Vector3d.new X_AXIS
            @state = 3
          if (@state == 3) # Rotating and stretching
            vec2 = @ip1.vector_to (ip)
            v1 = @vec1.angle_between X_AXIS
            v2 = vec2.angle_between X_AXIS
            #Sketchup.status_text = "@state = 3 ; v1; ", v1, " v2; ", v2, " @vec1; ",  @vec1
              #1 calulate delta_v if mousemove is counterclockwice and if vec1 and vec2 is in quadrant 1 or 2 of the unitcircle
              if ((v2>v1)  && ((vec2.x >= 0 && vec2.y > 0)  && (@vec1.x >= 0 && @vec1.y > 0)  || (vec2.x <=0 && vec2.y > 0) && (@vec1.x >= 0 && @vec1.y > 0 ) || (vec2.x <= 0 && vec2.y > 0) && (@vec1.x <= 0 && @vec1.y > 0)))
               delta_v = v2-v1
               #Sketchup.status_text = "@state = 3 ; ; v2>v1 ; Delta_v; ", delta_v
              #2 calulate delta_v if mousemove is counterclockwice and if vec1 and vec2 is in quadrant 3 or 4 of the unitcircle
              if ((v1>v2)  && ((@vec1.x <= 0 && @vec1.y < 0)  && (vec2.x <= 0 && vec2.y < 0)  || (@vec1.x <=0 && @vec1.y < 0) && (vec2.x >= 0 && vec2.y < 0 ) || (@vec1.x >= 0 && @vec1.y < 0) && (vec2.x >= 0 && vec2.y < 0)))
               delta_v = v1-v2
               #Sketchup.status_text = "@state = 3 ; ; v1>v2 ; Delta_v; ", delta_v
              #3 calulate delta_v if mousemove is clockwice and if vec1 and vec2 is in quadrant 1 or 2 of the unitcircle
              if ((v1>v2)  && ((@vec1.x <= 0 && @vec1.y > 0)  && (vec2.x <= 0 && vec2.y > 0)  || (@vec1.x <=0 && @vec1.y > 0) && (vec2.x >= 0 && vec2.y > 0 ) || (@vec1.x >= 0 && @vec1.y > 0) && (vec2.x >= 0 && vec2.y > 0)))
               delta_v = v2-v1
              #4 calulate delta_v if mousemove is clockwice and if vec1 and vec2 is in quadrant 3 or 4 of the unitcircle
              if ((v2>v1)  && ((vec2.x <= 0 && vec2.y < 0)  && (@vec1.x <= 0 && @vec1.y < 0)  || (vec2.x <=0 && vec2.y < 0) && (@vec1.x >= 0 && @vec1.y < 0 ) || (vec2.x >= 0 && vec2.y < 0) && (@vec1.x >= 0 && @vec1.y < 0)))
               delta_v = v1-v2
            @vec1 = vec2
            t_yv = Geom;;Transformation.rotation (@ip1, Z_AXIS, delta_v)
            @yv_group.transform! t_yv
           t_old = @yv_group.transformation
           Sketchup.status_text = "@state = 3 ; Transformation ", t_old
        end # onMouseMove
        def onLButtonDown (flags, x, y, view)
          if (@state == 3)
            @state = 4
          if (@state == 1)
            @state = 2
        end # onLButtonDown
        def reset
          @state = 0
      end # class YV_tool
           yvtool = YV_tool.new
           Sketchup.active_model.select_tool yvtool
      As you can see, the group turn around, but not directly at the mousepointer.
      I hope someone can come up with some ideas. πŸ˜‰ Until then I will keep fighting...
      Thanks in advance
      -RVS
      Get a Ruby
        Rasmus
        Find my FreeRotate.rb script - readily available on this ' Plugins' forum.
        It has a method of rotating the selection [which is temporarily grouped] so that it follows the cursor as it moves - it does this by constantly transforming the group and swapping the current value for the last one. In it you must pick two points to set the initial axis... but you could use your pt0=group.entities.parent.insertion_point insertion point [transformed by the tr=group.transformation as pt0.transform!(tr)] and then another logical point - perhaps pt1=pt0.offset(Z_AXIS,1) - or perhaps pt1=pt0.offset((pt0.vector_to(eye)),1) [where eye=model.active_view.camera.eye] - but this all depends on what point you want to rotate around and what initial 'vector' you want to use to kick-off with...
        πŸ€“
          rvs1977
          well thanks TIG! πŸ˜„
          I will study the script and hopefully get it πŸŽ‰
          Get a Ruby
