    LightUp 1.10 released
    extensions
    7 Posts 7 Posters 1.3k Views 7 Watching
    • AdamBA Offline
      AdamB
      Lots of new features and improvements in this release - the diffuse color bleeding is pretty neat, as is the 'shadow catcher' materials.
      Users can upgrade from the website: http://www.light-up.co.uk
      There is a new free demo to download if you want to give it a try.
      http://i614.photobucket.com/albums/tt229/ElektraGlide/cornell_lightup.jpg
      Changes for v1.10a
      • New Material attribute "Shadow Catcher" for creating realistic dropshadows on your skybox background
      • New control to set Fresnel color on materials, so color can change based on viewing angle.
      • New Ambient Occlusion shader supports color bleeding between surfaces
      • Being able to set "Autoplay" on exported LightUp Player files
      • Automatic triggering of Scene animation during Movie recording
      • Realtime rotation of Skybox in Tourtool (Alt+Drag left/right)
      • Added ability change FOV while inside Tourtool (Alt+Drag up/down)
      • Added show Cropping for standard ratios while inside Tourtool, to allow accurate framing
      • Added Bloom cutoff for better control of bloom
      • Honors "Use Hidden" for IrrCache also
      • Reads VTF texture file format
      • Fixes for stability of IES photometric light file handling
      • Fixed IES light aiming when embedded in Components and/or scaled.
      • Light aiming uses SketchUp inferencing
      • Improved Rayleigh sunlight model
      • Fixed problem of resetting bumpmap files on materials
      • Fixed problem of getting dark marks on some surfaces
      • Reduced noise in Ambient Occlusion shading
      • Fixed problem with binding wrong Irrcaches
      • Fixed reading of different skybox formats
      • Fixed problem with handling skinny faces
      • Fixed UV animation on shiney surfaces
      • Fixed FBX export handling of empty Groups
      • Improved Bloom cutoff algorithm
      • Fixed text input in dialogs jumping cursor to end of text
      • Much better IBL sampling quality
      • Better load balancing on multiple threads
      • Allow larger HDR skybox generation
        One more crazzy prog to test 😎
        PS Does it necessary to have a Net connection for install the demo prog?
        • PixeroP Offline
          Pixero
          Wow! Thanks. The color bleeding looks great.
          • shuraS Offline
            shura
            • X Offline
              xrok1
              seems like your going backwards 1.9 to 1.1 ????? the trailing 0 has no value so you might need to rethink your revision numbering 😳 1.09 to 1.1 might be more appropriate. πŸ˜‰
              one would expect ver 1.95 or 2.0 to be next πŸ˜•
              anyway keep up the good work you have a great plugin there.
              β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                sepo
                Great additions Adam. πŸ‘
                  No, the trailing zero has a significance - he's going from 9 to 10 (nine to ten).
                  And application version numbering isn't like normal decimal numbers, the numbers before and after the period is independent.
                  I for instance use versions like 1.4.2 (Major.Minor.Revision)
                  Major number increases in major application changes - like rewrites etc or when there's major compatibility changes.
                  Minor is often increased for new feature additions.
                  Revision is often just bug fixes.
                  There are different practices and norms though.
