    Dimension line offset
    layout
    7 Posts 4 Posters 2.2k Views 4 Watching
      Rogue
      Is there a way of offsetting the dimension line further from the object.
      I have tried selecting the dimension and scaling it away using the arrows,
      but the dimensions tend to change when i do that.
      Actual dimensions
      Selected dimensions
      Dimensions changed after move
        You can manually edit all dimensions. There could be two ways (the first one is rather cumbersome)
        The second one would be more straightforward:
        and after setting it, you can sample its style and apply it to all your other dimensions (even better; save it to your scrapbook and you can sample > apply it any time in other documents as well)
        • utilerU Offline
          utiler
          This should be able to be set as a default don't you think?
          Just Curious...
            Well, as I do not use LO "professionally" (unless posting in the forums is a "profession"), I do not have my own templates with all the bells and whistles but I am pretty sure it could be done with a custom template.
            However let's hope that in some upcoming, new version in the future this will be made easier.
            πŸ˜‰
            • utilerU Offline
              utiler
              We can only hope.....
              Just Curious...
                bjanzen
                LayOut 3 out today... it's there. We added a point to the line - there's now a connection point and an offset point.
                b
                  b
                  Well, you never know what comes next...
                  πŸ˜„
                  (I remember last time a painful workaround and png printing issue and when LO 2 came out, you were the first to suggest that png outpuit was then already available)
                  πŸ˜„
