    PHOTOMETRIC LIGHTS
    renderpluginsextensions
    6 Posts 5 Posters 3.7k Views 5 Watching
    • D
      Davi Melo
      FOR VRAY 1.48
      SITES WITH IES FILES FOR DOWNLOADS
      http://www.holophane.com/hlp_library/photometrics.asp?ProductType=Indoor&sCategory=Designer&FamilyID=97642&Family=Illuminaire&SubCategory=Holophorms
      http://www.americanelectriclighting.com/Library/Photometry/default.asp?path=/American_Electric_Lighting
      http://www.colorkinetics.com/support/ies/ (THE BEST)
      http://argajogja.files.wordpress.com/2009/08/tutorial3dsmaxieslight.jpg
      Davi Melo
      http://dm2projetos.blogspot.com/
      SKP8 - Vray 1.48
      WIN 7 ULTIMATE 64x
      INTEL CORE 2 QUAD 2.33GHz
      RAM 8GB
      NVIDIA GEFORCE 9600 GT
      • V
        vidy
        thanks for your link davi, a lot to try then...
        one question, is there a way to download all at once, for the last link you provide? thank you
        best regards,
        still so much to learn..
        • L
          lentak
          thanks
          • D
            dedmin
            Just to clarify - this files can be used with all rendering software that supports ies lights. Thanks for the links.
            • soloS
              solo
              yes.
              http://www.solos-art.com
              • D
                Davi Melo
                Guys,
                I'm creating a library with .IES lighting files for vray 1.48. They are available at:
                http://cid-b15d752486d2e557.skydrive.live.com/redir.aspx?resid=B15D752486D2E557!886&authkey=plYvz2uEXnQ%24
                For each file I'm creating a preview. For each IES there will be a JPG file, which will demonstrate the effect of light.
                the number between brackets in the filename represents the power of the light used in vray
                http://dnh7xa.bay.livefilestore.com/y1p9UPHy78ojhEqJyFlyYwoJ31k-df-walTM-cW4z7XuPvzHutZAjI-kQv_FlHTs6NNuC8I2KPREqBhHFuGYdEA14cmlUXNTHJo/ColorBlast6_clear [15.000].jpg?psid=1
                http://dnh7xa.bay.livefilestore.com/y1pfmXjUth3WMdM5NC0pI7MYvZxCzWY0kqNhvE9_jt84LQLv8XzOfeP--CMbJuixLlBqfqDJHLkqhfVdRk7QOX-gcIqoS-6aNOA/ColorBlast6 [15.000].jpg?psid=1
                good work!
                Davi Melo
                SKP8 - Vray 1.48
                WIN 7 ULTIMATE 64x
                RAM 8GB
