Saving selection to file, and placing on the mouse pointer.
11 Posts 4 Posters 821 Views 4 Watching
  • H Offline
    honoluludesktop
    Is there any simple way of attaching a selection of entities, or group to the mouse pointer? The only method I have found that would do that is import model. So, my second question, is is there any simple way of making a skp of a selection, or group of entities? I looked at this too, but could only find a method to save the whole model. As a test, I even tried to delete everything except the selection, then saved it, but even with a different name, the system would not (recursive?? error) import it back into the current model.
      You can save a component definition out to a file with this:
      http://code.google.com/apis/sketchup/docs/ourdoc/componentdefinition.html#save_as
      So you could take the selection, then turn it into a component, save that out, then explode the component (or don't, whichever). And I'm trying to rememeber, but it seems like when you add a component instance to the model, SU will stick it to the cursor automatically (sticking the "instertion point to the cursor).
      So perhaps converting to components is the way to go in this case?
      Chris
      All my Plugins I've written
        Yes, if you make a ComponentDefinition out of your entities, then you can use model.place_component.
        http://code.google.com/apis/sketchup/docs/ourdoc/model.html#place_component
        • H Offline
          honoluludesktop
          Thanks, I'll give that a try tomorrow.
          • H Offline
            honoluludesktop
            In order to get the entities in my_selection into my_definition, and make the file my_component.skp, is it necessary to do it for every entity as follows?
            my_selection.each do |e|
              if e.is_a? Sketchup;;Entity
                face = []
                if e.is_a? Sketchup;;Face
                  face = e.vertices
                  my_definition.entities.add_face face
                if e.is_a? Sketchup;;ComponentInstance
                  ci=e.definition
                  ti=e.transformation
                  my_definition.entities.add_instance(ci,ti)
                #do if end for each entity type
            success = my_definition.save_as "my_component"
            Or, is there an easier way? How do I make a curve an arc, or circle?
            • H Offline
              honoluludesktop
              For those who may be interested, here is the whole snippet. Problem is the selection attaches itself to the mouse pointer by the model's origin. Should have thought of that:-( Anyway, you may remove the "commented out" in the code to erase the selection from the model. Although you can recover by ^z, It needs a automatic undo, if you quit before locating the selection.
              Another problem is that Su entities are faces and edges, so arcs and circles lose their geometric attributes. Although you can add_... them, they are not Sketchup::Entities. Actually still not sure how all that stuff works.
              model = Sketchup.active_model
              definitions = model.definitions
              entities = model.entities
              selection = model.selection
              definition = definitions.add "Selection"
              my_definition = definitions.add "My Selection"
                    my_definition.entities.add_face e.vertices
              #   if e.is_a? Sketchup;;Curve
              #     result = my_definition.entities.add_curve e.vertices
              #   end
                  if e.is_a? Sketchup;;Edge
                    my_definition.entities.add_edges e.vertices
                    my_definition.entities.add_instance(e.definition,e.transformation)
                  if e.is_a? Sketchup;;Group
                    group = my_definition.entities.add_group
                    entities = e.explode
                    entities.each do |ge|
                      if ge.is_a? Sketchup;;Face
                        my_definition.entities.add_face ge.vertices
                      if ge.is_a? Sketchup;;Edge
                        my_definition.entities.add_edges ge.vertices
                  #e.erase!
              success = my_definition.save_as "mycomponent"
              show_summary = true
              status = model.import "mycomponent.skp", show_summary
              File.delete("mycomponent.skp")
                Why not group the selected entities and convert it into a component?
                • H Offline
                  honoluludesktop
                  OK, I'll give that a try.
                    rvs1977
                    How to attach a group to the mousepointer:
                    First, I think, you have to use the "Tool"-class, because in this class you have the onMouseMove-method.
                    (see also \plugins\examples\linetool.rb - it shows in detail how to use the tool-class)
                    class My_tool
                      def initialize # a good place to put variables. Notice the "@". It means you can see the variable
                                     # in the whole My_tool class. If no "@" it would only be visible inside the def.
                        @mod = Sketchup.active_model
                        @ent = @mod.entities
                        @state = 0
                         @pts = []
                         @pts[0] = [0,0,0]
                         @pts[1] = [10,0,0]
                         @pts[2] = [10,20,0]
                         @pts[3] = [0,20,0]
                      def activate  # activates the tool
                      def onMouseMove(flags, x, y, view)
                         ip = Sketchup;;InputPoint.new
                         ip.pick view, x,y
                         ip = ip.position
                         if (@state == 0) # Create Wall_group
                          @my_group = @ent.add_group
                          my_face = @my_group.entities.add_face @pts
                          my_face.pushpull -10
                          # ip is the input point from the mouse, converted to a 3d point
                          point = Geom;;Point3d.new ip
                          new_transform = Geom;;Transformation.new point
                          @my_group.transformation = new_transform
                          @state = 1
                        if (@state == 1) # @my_group follow mousemove
                          Sketchup.status_text = "@state = 1 ; Inputpoint; ", ip
                          new_transform = Geom;;Transformation.new (point)
                        if (@state == 2) # onLMouseButton place @my_group in choosen position
                          Sketchup.status_text = "@state = 2 ; Inputpoint; ", ip
                          @ip1 = ip
                          UI.messagebox "that should do it, Honolulu ;) - Press space to exit"
                          @state = 3
                      end # onMouseMove
                      def onLButtonDown (flags, x, y, view)
                        if (@state == 1)
                          @state = 2
                      end # onLButtonDown
                    end # class My_tool
                    # Here you activate the defined tool in your program...
                         mytool = My_tool.new
                         Sketchup.active_model.select_tool mytool
                    Regards RVS 😄
                    Get a Ruby
                      If you just want to place the a component you can simply SU's use native tool model.place_component
                      • H Offline
                        honoluludesktop
                        RVS, thanks for help with the snippit. I have another use for it.
                        tt, finally got to it, shoot, that was too easy:
                        my_def = definitions.add "My Selection" my_inst = @master_group.to_component my_def.entities.add_instance(my_inst.definition, my_inst.transformation) my_inst.erase! repeat = false model.place_component my_def, repeat
