    Saving selection to file, and placing on the mouse pointer.
    11 Posts 4 Posters 1.2k Views 4 Watching
    • honoluludesktopH Offline
      honoluludesktop
      Is there any simple way of attaching a selection of entities, or group to the mouse pointer? The only method I have found that would do that is import model. So, my second question, is is there any simple way of making a skp of a selection, or group of entities? I looked at this too, but could only find a method to save the whole model. As a test, I even tried to delete everything except the selection, then saved it, but even with a different name, the system would not (recursive?? error) import it back into the current model.
      • Chris FullmerC Offline
        You can save a component definition out to a file with this:
        http://code.google.com/apis/sketchup/docs/ourdoc/componentdefinition.html#save_as
        So you could take the selection, then turn it into a component, save that out, then explode the component (or don't, whichever). And I'm trying to rememeber, but it seems like when you add a component instance to the model, SU will stick it to the cursor automatically (sticking the "instertion point to the cursor).
        So perhaps converting to components is the way to go in this case?
          Yes, if you make a ComponentDefinition out of your entities, then you can use model.place_component.
          http://code.google.com/apis/sketchup/docs/ourdoc/model.html#place_component
            honoluludesktop
            Thanks, I'll give that a try tomorrow.
              honoluludesktop
              In order to get the entities in my_selection into my_definition, and make the file my_component.skp, is it necessary to do it for every entity as follows?
              my_selection.each do |e|
                if e.is_a? Sketchup;;Entity
                  face = []
                  if e.is_a? Sketchup;;Face
                    face = e.vertices
                    my_definition.entities.add_face face
                  if e.is_a? Sketchup;;ComponentInstance
                    ci=e.definition
                    ti=e.transformation
                    my_definition.entities.add_instance(ci,ti)
                  #do if end for each entity type
              success = my_definition.save_as "my_component"
              Or, is there an easier way? How do I make a curve an arc, or circle?
                honoluludesktop
                For those who may be interested, here is the whole snippet. Problem is the selection attaches itself to the mouse pointer by the model's origin. Should have thought of that:-( Anyway, you may remove the "commented out" in the code to erase the selection from the model. Although you can recover by ^z, It needs a automatic undo, if you quit before locating the selection.
                Another problem is that Su entities are faces and edges, so arcs and circles lose their geometric attributes. Although you can add_... them, they are not Sketchup::Entities. Actually still not sure how all that stuff works.
                model = Sketchup.active_model
                definitions = model.definitions
                entities = model.entities
                selection = model.selection
                definition = definitions.add "Selection"
                my_definition = definitions.add "My Selection"
                      my_definition.entities.add_face e.vertices
                #   if e.is_a? Sketchup;;Curve
                #     result = my_definition.entities.add_curve e.vertices
                #   end
                    if e.is_a? Sketchup;;Edge
                      my_definition.entities.add_edges e.vertices
                      my_definition.entities.add_instance(e.definition,e.transformation)
                    if e.is_a? Sketchup;;Group
                      group = my_definition.entities.add_group
                      entities = e.explode
                      entities.each do |ge|
                        if ge.is_a? Sketchup;;Face
                          my_definition.entities.add_face ge.vertices
                        if ge.is_a? Sketchup;;Edge
                          my_definition.entities.add_edges ge.vertices
                    #e.erase!
                success = my_definition.save_as "mycomponent"
                show_summary = true
                status = model.import "mycomponent.skp", show_summary
                File.delete("mycomponent.skp")
                  Why not group the selected entities and convert it into a component?
                    honoluludesktop
                    OK, I'll give that a try.
                      rvs1977
                      How to attach a group to the mousepointer:
                      First, I think, you have to use the "Tool"-class, because in this class you have the onMouseMove-method.
                      (see also \plugins\examples\linetool.rb - it shows in detail how to use the tool-class)
                      class My_tool
                        def initialize # a good place to put variables. Notice the "@". It means you can see the variable
                                       # in the whole My_tool class. If no "@" it would only be visible inside the def.
                          @mod = Sketchup.active_model
                          @ent = @mod.entities
                          @state = 0
                           @pts = []
                           @pts[0] = [0,0,0]
                           @pts[1] = [10,0,0]
                           @pts[2] = [10,20,0]
                           @pts[3] = [0,20,0]
                        def activate  # activates the tool
                        def onMouseMove(flags, x, y, view)
                           ip = Sketchup;;InputPoint.new
                           ip.pick view, x,y
                           ip = ip.position
                           if (@state == 0) # Create Wall_group
                            @my_group = @ent.add_group
                            my_face = @my_group.entities.add_face @pts
                            my_face.pushpull -10
                            # ip is the input point from the mouse, converted to a 3d point
                            point = Geom;;Point3d.new ip
                            new_transform = Geom;;Transformation.new point
                            @my_group.transformation = new_transform
                            @state = 1
                          if (@state == 1) # @my_group follow mousemove
                            Sketchup.status_text = "@state = 1 ; Inputpoint; ", ip
                            new_transform = Geom;;Transformation.new (point)
                          if (@state == 2) # onLMouseButton place @my_group in choosen position
                            Sketchup.status_text = "@state = 2 ; Inputpoint; ", ip
                            @ip1 = ip
                            UI.messagebox "that should do it, Honolulu ;) - Press space to exit"
                            @state = 3
                        end # onMouseMove
                        def onLButtonDown (flags, x, y, view)
                          if (@state == 1)
                            @state = 2
                        end # onLButtonDown
                      end # class My_tool
                      # Here you activate the defined tool in your program...
                           mytool = My_tool.new
                           Sketchup.active_model.select_tool mytool
                      Regards RVS πŸ˜„
                      Get a Ruby
                        If you just want to place the a component you can simply SU's use native tool model.place_component
                          honoluludesktop
                          RVS, thanks for help with the snippit. I have another use for it.
                          tt, finally got to it, shoot, that was too easy:
                          my_def = definitions.add "My Selection" my_inst = @master_group.to_component my_def.entities.add_instance(my_inst.definition, my_inst.transformation) my_inst.erase! repeat = false model.place_component my_def, repeat
