    Surface terrain to a "level" terrain
    5 Posts 5 Posters 522 Views 5 Watching
      donaldaugustsson
      ok, for the first you have to excuse me for not finding the correct word for what im looking after. Because of that im gonna attach a picture that i hope can explain what im after.
      I have a surface and i want to convert it to a "leveled" terrain - like the old school models made by hand.
      I know that you can insert plans and so on to make the heightdifferent visible... but thats not what im looking for - i want the terrain to be like stairs...
      This is the way
      • ToboboT Offline
        Tobobo
        After a few minutes of head scratching i got!!!
        What you have to do is flatten the contours then create faces for them the use the push pull tool the bring them the the required height.
        Its a long a boring process if you have loads of contours.
        Toby
        Philippians 4:13
        • EarthMoverE Offline
          EarthMover
          I would take the contour lines and Drape them onto a flat surface of the same width. Then run Make Faces plugin and as Toby said, manually lift each section to height.
          Content Creator at Skapeup
            aks a ruby script request
            existing Colors by Slope, Z by colors, it's just the inverse πŸ˜‰
            (better if you have yet a color plane level! )
            • honoluludesktopH Offline
              honoluludesktop
              Not sure, but this might help you. I think that you may have to rotate your model before slicing, as a quick read is that it slices in the x, z plane.
