    How to set Layer property of a Group?
    7 Posts 4 Posters 767 Views 4 Watching
    • G Offline
      GrojGuy
      I'm really sorry to post such a seemingly-simple question, but I'm at a loss where to discover the answer, after significant searching.
      In Ruby, how does one assign the Layer property of a Group? (there is no Group.layer= method)
      Thanks...
        Notice that in the API docs, above the list of methods for each class it says "Parent:". And for Group it says:
        Parent: Drawingelement
        And the Drawingelement class has a layer property.
        Have a look at the Objects Diagram for an overview of the classes' relationships:
        http://code.google.com/apis/sketchup/docs/diagram.html
        • G Offline
          GrojGuy
          Thank you. I had seen that, but was thrown off a little the "Introduction" for "Drawingelement" which states...
          ...These items include edges, contruction points, construction lines, and images...
          No mention of "groups" (which did seem contradictory to the Objects Diagram). But now I see I need to get more familiar with the API Object structure.
          • Dan RathbunD Offline
            Dan Rathbun
            What Thomas left unsaid, is that a subclass inherits methods from it's superclass.
            At the Ruby console, type:
            Sketchup::Group.instance_methods.sort
            .. and you'll see that the group class has inherited a layer= method.
            I'm not here much anymore.
            • G Offline
              GrojGuy
              Ah yes, OK, that would make sense, i.e. class inheretance. But, from your comment I was anticipating seeing "layer=" in the instance methods list returned by that nifty command...
              Sketchup;;Group.instance_methods.sort
              (eval);64; warning; instance_methods; parameter will default to 'true' as of 1.8.1
              ["add_observer", "copy", "createObservers", "definition", "description", "description=", "entities", "explode", "local_bounds", "locked=", "locked?", "make_unique", "move!", "name", "name=", "remove_observer", "to_component", "transform!", "transformation", "transformation="]
              So, why is "layer=" it not in the list?
                There are several methods that apply to certain classes that aren't listed as they are 'subsidiary'.
                These include
                group.layer= instance.layer= group.material= instance.material= group.erase! group.hidden=
                The list is in http://code.google.com/apis/sketchup/docs/ourdoc/drawingelement.html
                for 'drawingelements' - which applies to these kind of things too...
                If in doubt try them... you can but fail...
                  Dan Rathbun
                  Because.. you see the warning for the "show inherited" argument is default false for your version of Ruby, but will (actually was,) changed to true as a default, in all Ruby versions 1.8.1 and higher.
                  IF you are still using Sketchup 7.x, then the Ruby DLL distro'd is v1.8.0-initial_release (ie: patch_level p0)
                  You can backup the current "Deceased 1.8.0" dll, msvcrt-ruby18.dll by renaming it: msvcrt-ruby180_p0.dll
                  then replace it with your choice of a newer version from: Ruby Interpreter DLLs (Win32) (you will need to make a copy of the version you want Sketchup to load named: msvcrt-ruby18.dll.)
