    Snappy Tabs
    5 Posts 5 Posters 1.5k Views 5 Watching
    • J
      Jim
      User Interface, get out of the way. Wishlist worthy?
      Actually, what I'd like to see are vertical tabs, or a auto-hide sidebar, used for these windows.
      • mitcorbM
        mitcorb
        Ohhhh,yeahhh!
        • thomthomT
          With the option to tear off. Like you have in PhotoShop, you have panels which can be pulled off and made into a tab or attached under another section, or free floating.
          • GaieusG
            But then also to add/remove tabs (like you do not display the components tab and some may or may not need the shadows tab or the fog tab).
            But then sometimes I like to have more of them open at the same time. Often I have the entity info window open and active and though it is annoying when popping up and down depending what I select, it is useful.
            Nevertheless with some of these and the above extra ideas/tweak, it could indeed be a nice feature!
            • I
              infact
              I heard there is a plugin that makes this possible (see this thread).
