    [Plugin] Dxf_In v2.2 20110517 Dxf2Skp
    200 Posts 41 Posters 287.4k Views 41 Watching
      alexdobras
      Honoluludesktop: thank you very much for this plugin
      one thing though, i tested on a file and i saw that the it doesn't import the text intro SU.
      could you adjust that please, also if it is possible to add the possibility to maintain the Cad Layers on SU, after the import.
      thanks a tonne!
      • honoluludesktopH Offline
        honoluludesktop
        Hi Alex, Go here for a plugin to import text separately into your SketchUp model. Can you post the dxf file so that I can work on layers?
          alexdobras
          here is the pdf of what should appear in SU , but only in CAD, as DraftSight, which is new and free sees :
          small-victoria_cuerpo_bello.pdf
            alexdobras
            i give you the files that i have to work with.
            the big one is the one i need, but since is so big, and take a lot of time to import, i made another(smaller) with only a section of the model, so can take a look rapidly
            here is the link from where you can access them: http://dl.transfer.ro/transfer_ro-24mar-5c4a282f1f55.zip
            small part-VICTORIA_CUERPO_BELLO.dxf
            notice! i didn't explode the model, so they can import badly with lacking of details. I don't find where i put the exploded ones. If you need them too, tell me, and i will upload them also.
            and by the way the import_text makes SU crashing when i want to import the file 😞 that's why i'm asking
              honoluludesktop
              Got it, will get back to you after I have a chance to look at it. Good job, cutting the size down.
                honoluludesktop
                Alex, Test this version in regards to layers. I see that there are transformation problems with blocks that I will also have to fix. Temp00.pngIn addition, Dxf_In currently doesn't support nested blocks. Read the help files; also set the defaults dimensions to your preference.my_dxf_In_v1.25.rbLet me know if the layers are OK so that I can post the plugin for others.
                  alexdobras
                  i have made another file, much simple one.
                  0 (contains a polyline)
                  blue circle
                  red rectangle
                  yellow Block
                  Though layer system now works with your new plugin, but is not accurate: i ,mean the red rectangle is placed on Layer0(of SU default), but it should appear on a different one: that is Red Rectangle not to be placed on Layer0(defaultSUlayer).
                  (bytheway: if i hide Layer0-everything dissapears- this is strange because on layer Red Rectangle should be only a rectangle, and SU for some reason puts the rectangle on Layer0 with also everything!! strange, you can see that is no Red Rectangle layer in SU, after importing the file)
                  here's the file, please check it out.
                  testlayers.dxf
                    alexdobras
                    it would be best to make possible to add the layers imported into Su, on different layers than SU's layers, cause currently it puts some geometry on Layer0 of SU, which is not good at all.
                      alexdobras
                      the rectangle lacks an edge for some reason by the way, as seen here:see.PNG
                        alexdobras
                        Also: Blender 2.49 has a very powerful DXF importer. I have tested it and installed everything includin text blocks all correct , without an error. Single thing that is not working are the layers. Unfortunately blender in not as quick and simple as SU 😐
                        I wonder if you could take a look into how that Importer in made, so you could adapt it to SU.
                          honoluludesktop
                          SketchUp layers are unlike those in other Cad applications. I think that the view layer is correct. If you elect to group the import at the end of running the application, the group will be placed on "layer0", and hiding/unhiding layers behaves as you see it. If you do not group the import, it should work in a more conventional manner. I will look at the problem with placing the entities on the wrong layer.
                            honoluludesktop
                            Alex, good news is "layer0" is "RED_RECTANGLE" so the problem is fixable. Bad news, the missing entities may be "unsupported" by Dxf_In. Sorry, but the math for those entities may be (or not) beyond me. I will take a look.
                            Is the attached image the one that you are looking for?Temp00.pngIf not tell me what is wrong? The line that intersects the circle is on "layer0". I suspect that is wrong. Can you tell me what layer it's on? Perhaps layer "0".
                              alexdobras
                              Is the attached image the one that you are looking for?[attachment=0:fq5clw9c]<!-- ia0 -->Temp00.png<!-- ia0 -->[/attachment:fq5clw9c]If not tell me what is wrong? The line that intersects the circle is on "layer0". I suspect that is wrong. Can you tell me what layer it's on? Perhaps layer "0".
                              it is almost good
                              the line that intersects the circle is on layer named "0" on CAD, but i see that is on "Layer0" of Sketchup. that is bad, because SU should create the later named "0", so the dxf imported should pe placed on totally different layers than that existing ones.
                              also: how could you import the dxf and get the entire rectangle, and almost the Block completely imported??
                                alexdobras
                                there should be 5 layers:
                                layer0
                                red rectangle
                                yellow Block
                                Blue circle
                                  In a DWG/DXF import the CAD layer '0' shouldbecomes= SKP layer 'Layer0' [nil]
                                  Other layers should be named to suit... πŸ˜’
                                    alexdobras
                                    here are the layers in SU:
                                    please notice that there is Layer0 and 0
                                      alexdobras
                                      here is the layout in DraftSight :
                                      notice that the name "red rectangle" disappears from the layer tab in SU.
                                      i don't know what you did Honoluludesktop, that you got the picture earlier showed.
                                      and by the way, how did you get all the lines importing accurately ?
                                        honoluludesktop
                                        Looks like you got another post in while I was writing the other.>_< The accurate image is based another application that I use to check my work. I placed the SU layer window over it in order that you can ID the layers.
                                          honoluludesktop
                                          Yes, in my case, "Red_Rectangle" is missing. While I am moving ahead on this, I would like to get the opinion of those that are more experienced then myself. Bottom line is that the app. should conform to Acad, GCD/4D (the reason I wrote this plugin), and SU specifications.
                                          Btw, Dxf_In currently doesn't do splines, ellipses, or polyface entities. Ellipsis can be added in the future, but polyface entities, and splines are outside of my comprehension of their computer math algorithms.
                                            alexdobras
                                            but how did you get that accurate importing? i see all the lines in your SU
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 5 / 10
