    [Request]Radial lines 2D, 3D
    10 Posts 3 Posters 989 Views 3 Watching
      If not yet exist πŸ˜„
      Radial lines from a same point with a measure given or not πŸ€“
      For avoid to come back at the start point!
      β˜€
      (difficulty is avoid also faces creation (option Y/N) πŸ˜‰
      Will be nice in the 2D Tools set by TIG πŸ˜„
      • TIGT Online
        ### (c) TIG 2010
        ### 'radiallines' for Pilou
        ### select one cpoint and some edges/faces
        ### type radialllines in the Ruby Console.
        ### it adds clines from the cpoint to every selected vertex
        ### and central text for the distance.
        def radiallines()
          model=Sketchup.active_model
          ss=model.selection
          sa=ss.to_a
          cp=nil
          vs=[]
          sa.each{|e|
            cp=e if e.class==Sketchup;;ConstructionPoint
            e.vertices.each{|v|vs << v if not vs.include?(v)} if e.class==Sketchup;;Face
            if e.class==Sketchup;;Edge
              vs << e.start if not vs.include?(e.start)
              vs << e.end if not vs.include?(e.end)
            end#if
          if not cp
            UI.messagebox("Selection must contain a Cpoint!")
            return nil
          end#if
          if not vs[0]
            UI.messagebox("Selection must contain a Vertex!")
            return nil
          end#if
          model.start_operation("Radial Lines")
          ss.clear
          layer1=model.layers.add("RADL-LINE")
          layer1.visible=true
          layer2=model.layers.add("RADL-LINE-TEXT")
          layer2.visible=true
          ents=model.active_entities
          base=cp.position
          cb=ents.add_cpoint(base)
          cb.layer=layer1
          points=[]
          vs.each{|v|points << v.position}
          points.each{|p|
            pc=ents.add_cpoint(p)
            pc.layer=layer1
            cl=ents.add_cline(base,p)
            cl.layer=layer1
            dis=base.distance(p)
            mid=base.offset(base.vector_to(p), dis/2)
            text=dis.to_l.to_s
            txt=ents.add_text(text,mid,[0,0,0])
            txt.layer=layer2
            txt.leader_type=0
            txt.arrow_type=0
            txt.display_leader=false
          model.commit_operation
        πŸ€“
        It adds clines BUT you can change 'add_cline' to 'add_line' to make 'Lines'...
        You can also NOT change the lines/text layers by ### out those lines...
        • TIGT Online
          If you want to add lines to any points within a range of max/min distances then that's different...
            davidlouis
            Hi TIG
            Could you please turn this into a proper plugin file that would appear in the plugins menu.
            I have saved the code to an .rb file in notepad but i can't find it in sketchup or load it from the console...
            This could help a lot with urban analysis but also in creating a series of guidelines from say a column head out to a series of points on a roof to create a wireframe of a roof structure which could then be converted into actual stuctural elements using say profile builder or otherwise. An option to leave the text off in the latter case would be good too!
            Dave
            • TIGT Online
              I'll issue it as a script... πŸ˜’
              @Pilou - the current text needs to go into a file called radiallines.rb in the Plugins folder,
              Currently to run it you type radiallines in the Ruby Console.
              A ' cpoint' is a Guide [Construction] Point - and a ' cline' is a Guide [Construction] Line.
                Oh Speedy reply β˜€
                Just some precision and questions
                I suppose I must save the text code above as radiallines.rb for use it?
                It's a "standalone RB"?
                for the moment I obtain that
                Error; #<NameError; (eval);27; undefined local variable or method `radiallines' for main;Object>
                What is exactly a "Cpoint" it's given by the Tape measure tool or the Protractor tool or... I have a little problem of memory on this 😳
                It's a "Guide Point"? (so a tool's bar of Didier Bur have that)
                  Ok that is that I had presummed, but there is always the error message above πŸ˜‰
                  I select a Cpoint, and some faces, segments
                  then call the plug by the ruby console but error message above persists πŸ˜‰
                    davidlouis
                    Its working on my side (via the console)... I had to change the cline to a line so that i could 'trace' them into structural entities... profile builder didn't recognise the cline...
                    Is either cline or line an option that can be built in?
                    Dave
                    • TIGT Online
                      Here's the new 'tool' that does what you want... http://forums.sketchucation.com/viewtopic.php?p=273614#p273614
                        Never works for me with the console but now with the new ruby that works like a charm 😎
