    If local_variable == @variable
    8 Posts 3 Posters 504 Views 3 Watching
    • honoluludesktopH Offline
      honoluludesktop
      My SU page fonts are huge today,-), my eyes are not that bad, yet. Anyway I notice that I can not test different kinds of variables, as the following fails:
      def anything
        something
        if local_variable == @variable
          something
        else
          something else
      While the following works:
      def anything
        something
        if @local_variable == @variable
          something
        else
          something else
      Is it a rule in Ruby that you can not test different kinds of variables? Is there other things I need to be aware of because of this?
        SCF you mean? At the top of the page, upper right, you can swap between sizes.
        Fails with error message, or just doesn't do what you want?
        There should be no restrictions, but are you sure you defined all the variables?
          honoluludesktop
          Yeah, at the office, I get to adjust the view zoom font %, so I found that I had to scale down from 125% to 100%. Don't know why the machine woke up at 125%.
          Don't recall error massage, but I didn't separately declare the local variable (vari_1 = 0, vari_2 = 0). OK, I thought that local variables could be created on the fly. Sigh...
            ` x=3
            3
            puts 'hello' if y == x
            Error: #<NameError: undefined local variable or method y' for main:Object> (eval):15
            when comparing you need to have initialized the variable.
              Note that instance variables doesn't act the same:
              puts 'hello' if @y == x nil
                honoluludesktop
                OK, thanks.
                • fredo6F Offline
                  fredo6
                  def anything
                  >   something
                  >     something
                  >   else
                  >     something else
                  >   end
                  > end
                  def anything
                  >   something
                  >     something
                  >   else
                  >     something else
                  >   end
                  > end
                  you need to initialize the local variables. Otherwise you get an error.
                  Instance variables (with @) are initialized to nil by default, and this is why you don't get an error.
                  Fredo
                    And class variables @@.
