    Materials vs. Entities in model (screenshot)
    13 Posts 5 Posters 805 Views 5 Watching
      draftomatic
      Can someone explain this screenshot to me? I tried to delete one of those 8 Materials. Where are these materials being used? I even killed Susan...
      So how do I get a list of all Materials on existing Entities? Must I loop through model.entities?
      • soloS Offline
        solo
        You deleted her but never 'purged' the scene, Purging will remove materials.
        http://www.solos-art.com
        • Chris FullmerC Offline
          +1
          Open your component Browser and look at the "in model" tab. It will show that there is still at least 1 component in the model. It is not being drawn anywhere in the model, but it still has a component definition saved in the model, so the model still considers the colors as being used.
          Chris
          All my Plugins I've written
            Note: model.materials.length also include materials which Image element uses.
            Say you have 2 materials listed in SU's material browser:
            Material1
            Material2
            And you also have one Image element in the model.
            Then model.materials.length will report 3.
            Even more:
            Sketchup.active_model.materials.each { |m| puts m.display_name } Material1 Material2
            Notice it only lists the two material visible in the material editor.
            This on the other hand:
            (0...Sketchup.active_model.materials.length).each { |i| puts Sketchup.active_model.materials[i].display_name } Material1 Material2 Image1
            Now you get full access to all the material - even the ones that belong to Image elements.
            Be careful! I've had models where image materials has been applied to other geometry - which has lead to problems as you can't select or interact with the material in the Material Browser. So in most cases you want to iterate using .each.
            To get a count of just the materials available in the material browser:
            m_count = 0 Sketchup.active_model.materials.each { m_count += 1 }
              draftomatic
              Cool... except that I purged and there is still one material left - "0135_DarkGray". What's up now?
                You have it selected. The currently active material will not be purged. Select the default material before you purge.
                  draftomatic
                  I see... is there a way to find/change the currently active material thru Ruby?
                    Sketchup.active_model.materials.current = nil
                      material.current is not in the API docs. Do we have that in the thread of things for Scott to fix?
                        Sorry, it's model.materials.current
                          😳 Sorry, I could have checked that....
                            Is that being checked by Scott still?
                            I'm a bit confused if we're supposed to comment in the API docs...
                              There is a reported difference between materials.current on PC and MAC.
                              On a PC it's the currently selected material
                              On a MAC it's the last used material and this ignores what might now be selected IF it's never been used... πŸ€“
