    Load an object and attached it to the pointer
    10 Posts 4 Posters 1.1k Views 4 Watching
    • S
      sm4rt
      Hi all,
      I got a new problem using ruby in sketchup...
      I tray to create a dialog box which let user to load some objects inside the "component folder". I've successfully made it but I would like to attached the object loaded to the pointer in order to place it with the mouse like sketchup do when we drag and drop some SKP from desktop to the working window...
      here is a simple example :
      # First we pull in the standard API hooks.
      require 'sketchup'
      # Add a menu item to launch that one.
      UI.menu("PlugIns").add_item("Load Tree") {
       # Method calling.
        load_Tree
      def load_Tree
       # Prompt parameters dialogue
       prompts = ["X in cm","Y in cm","Z in cm"]
       defaults = ["0","0","0"]
       list = ["","",""]
       input = UI.inputbox prompts, defaults, list, "Origine Point"
      pannelType = "MyTree.skp"
      model = Sketchup.active_model
      entities = model.active_entities
      path = Sketchup.find_support_file pannelType ,"Components/"
      definitions = model.definitions
      componentdefinition = definitions.load path
        x0= input[0].to_i / 2.54
        y0= input[1].to_i / 2.54
        z0= input[2].to_i / 2.54
      point = Geom;;Point3d.new x0,y0,z0
      transform = Geom;;Transformation.new point
      instance = entities.add_instance componentdefinition, transform
       if (instance)
          UI.messagebox "Tree successfully loaded"
       else
          UI.messagebox "Failure"
      My goal is to delete the "x,y,z" arguments in the dialog box and place the object with mouse but I can't find anything inside the Google API and I turn in a round reading it...
      I think it's possible and quite easy to do that...
      Thanks for your suggestions
      • TIGT
        http://code.google.com/apis/sketchup/docs/ourdoc/definitionlist.html#add
        adds a new definition by 'name' to the model's definitions list [no instances].
        http://code.google.com/apis/sketchup/docs/ourdoc/definitionlist.html#load
        loads a definition to the model's definitions list from an external skp_path [no instances].
        http://code.google.com/apis/sketchup/docs/ourdoc/entities.html#add_instance
        places an instance of the definition at the given transformation.
        http://code.google.com/apis/sketchup/docs/ourdoc/model.html#import
        imports a file [several types] - if it's a SKP file then it also inserts an instance of the definition and attaches it to the cursor! [it is of course also 'loaded' into the model's definitions list so it is accessible]
        You can also write a tool which takes the cursor position as a 'point' and dynamically changes the instance's position as you move the pointer, until you left-click and then that is the instance's location... πŸ€“
        • honoluludesktopH
          honoluludesktop
          TIG, thanks for the mini tut. Until this post, I didn't realize that every component in the model was a "instance". I previously thought that when you created a definition, that a component was automatically created in the model. That's wrong, right?-)
          When you delete all occurrences of a component from a model, it remains in Window > Components. This is a definition, yes?
          • TIGT
            A model contains 'component definitions' [ model.definitions].
            These are stored in the model's data-base and may or may not have been be 'used'.
            All of these show in the 'Component Browser' window's 'model' tab list.
            If you use ' definitions.purge_unused' then all component definitions that haven't been 'used'
            are removed from the data-base and the 'Component Browser' window's 'model' tab list.
            ***When a 'component definition' is 'used' [i.e. it is 'added' into the model] it becomes a 'component instance'.
            There are two ways of 'importing' a SKP as a new component - the first loads a component to the definitions_list - model.definitions.load(skp_path).
            You can then manually insert an instance of that definition into the model by picking it from the 'Component Browser' or use code, as in entities.add_instance(definition,transformation).
            The second way is model.import(path.skp) which imports the SKP as a new component and it arrives on your cursor with its insertion-point at the imported SKP's origin.
            Of course after the definition is imported it is also 'loaded' so you can then use the .add_instance() method on it later if multiple copies are needed.
            You use new_defn=model.definitions.add(skp_name) - to make a new definition in the model's data-base [ new_defn] to which you can add new entities - [ .add_...(...) methods] e.g. new_defn.entities.add_cpoint(pt) etc.
            To remove a single definition from the model [ purge_unused removes all unused and you probably don't want that] you need to erase all of the definitions entities so that it is empty, this needs to be done inside a model.start_operation("...")...model.commit_operation code-block - then all instances will vanish and the entry will be removed from the 'Component Browser' window list too [Note: there are several ways to erase 'all entities' - the best is probably definition.entities.erase_entities(definition.entities.to_a)].
            To remove an instance and leave the definition alone use instance.erase!.
            To change the contents of a definition [that will affect all instances] use definition.entities.add_...(...) methods or [ruby:1elixfc4]entity.erase![/ruby:1elixfc4] to remove a specific thing.
            If you want to change the contents of only one instance and leave the others unchanged first make the instance unique and then change its definition:
            [ruby:1elixfc4]instance.make_unique
            definition=instance.definition[/ruby:1elixfc4]
            So an instance has a definition [instance.definition], and a definition has instances [definition.instances] - these are useful hooks... For example - to test if a definition is in use [ruby:1elixfc4]definition.instances[0][/ruby:1elixfc4] will return true [at least one] or false if none.
            πŸ€“
            • honoluludesktopH
              honoluludesktop
              Thanks, now to find the time to actually put this into practice.
              • thomthomT
                Beware the model.definitions also include definitions for Groups and Images, not just ComponentInstances. There are .group? and .image? test methods for ComponentDefiniton one can use to filter out the various types.
                • S
                  sm4rt
                  Thanks for answering.
                  So I trayed that :
                  require 'sketchup'
                  UI.menu("PlugIns").add_item("My Models") {
                   # Ruby Console after click
                   Sketchup.send_action "showRubyPanel;"
                   # Method calling.
                    load_MyModels
                  def load_MyModels
                   show_summary = true
                   status = model.import "Components/MyComponent.skp", show_summary
                  But Sketchup return me that it could not find the file I've placed in the component folder ?
                  • thomthomT
                    Specify a full path.
                    • TIGT
                      status = model.import("Components/MyComponent.skp", show_summary) won't work because the path is bad.
                      You need to get the path to the file thus...
                      path=Sketchup.find_support_file("MyComponent.skp", "Components/")
                      it will ==nil IF it's not there...
                      then use
                      status = model.import(path, show_summary)
                      πŸ€“
                      • S
                        sm4rt
                        And it work ! 😍
                        Thank y'all for your help...
