    Scale in layout question
    layout
    3 Posts 2 Posters 1.4k Views 2 Watching
      Ands43
      Working on a imac.
      I have inserted my image - right click - scale - then there are options such as 1:50, 1:200, 1:1000.
      Is there a way of specifying my own scale say 1:75 or 1:33.3. When I grab the blue frame there are measurements changing in the bottom right hand corner, if I go to alter these by moving my arrow away from the blue frame the measurements lock so I can't type in the box. Does that make sense.
      This is an issue for me as I'm being asked to do plan and elevation drawings in sketchup.
        JuanV.Soler
        I run windows, but maybe the same,
        if you click under Layout preferences you can custom your own scale
          Ands43
          gracias!!! 😍 so simple!!
