    The case of the missing data
    5 Posts 3 Posters 403 Views 3 Watching
    • honoluludesktopH Offline
      honoluludesktop
      Not sure if anyone can find my error just in the code snippet below. The first set of puts ID's the start, and dumps the data. The second set of puts, shows the results, and the missing "0.0". I have traced the data and it is OK up to here:
      @block_z = @insert_names[0] @insert_names = @insert_names - [@insert_names[0]]
      In that step, "0.0" vanishes. Any ideas?
      The portion of my code:
      if @line == @insert_names[0
      puts "start"
      puts @insert_names
      @block_name = @insert_names[0]
      @block_x = @insert_names[0]
      @block_y = @insert_names[0]
      puts "end"
      puts @insert_names
      end]
      and the results of the puts:
      %(#0000FF)[start
      GROUP_1
      -4.944653
      -6.740773
      0.0
      GROUP_2
      8.629024
      -6.771204
      0.0
      GROUP_1
      -4.944653
      -6.740773
      0.0
      start
      GROUP_2
      8.629024
      -6.771204
      GROUP_2
      8.629024
      -6.771204
      nil]
        not sure about the data - but is this line removing the first item of the array?
        you can do that with:
        @insert_names.shift
          You are really tangling things by reducing the contents of @insert_names as you go along - it becomes hard to keep track...
          Because you know the order, then why no extract the data 4 items at a time?
          blocks=[] ### or whatever you want to call this array of 'blocks'...
          inserts=[]+@insert_names ### == a 'copy'
          while inserts[0]
            block=[]
            block[0]=inserts[0]
            block[1]=inserts[1]
            block[2]=inserts[2]
            block[3]=inserts[3]
            blocks << block
            inserts=inserts[4..-1]
            ### strip out first block recursively...
          end#while
          ### now 'blocks' contains arrays for each block followed by its x/y/z
          ### e.g. [[GROUP_1, -4.944653, -6.740773, 0.0],[GROUP_2, 8.629024, -6.771204, 0.0]...]
          ### '@insert_names' is unchanged.
          πŸ€“
            honoluludesktop
            Thanks fellows, let me give those a try:-)
              honoluludesktop
              Thanks, they both work:-) Ended up fixing my app in a couple of places. Wounder how I mucked the data:-(
