    Can't assign a shortcut to a plugin
    3 Posts 2 Posters 442 Views 2 Watching
    • halroachH Offline
      halroach
      I've installed select instancev2 by M. Bekhor, downloaded from:
      http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=365
      (I find this plugin one of the more powerful instance selection tools).
      I am trying to assign a keyboard shortcut, but I can't find the command in the shortcuts list.
      How can I do this?
      Is there something I'd need to update in the plugin to make it reachable in the shortcuts list?
      Thanks!!
      FlexTools - Super Quick Windows, Doors, Slats...
      • jeff hammondJ Offline
        jeff hammond
        How can I do this?
        Thanks!!
        you probably have to select (something) prior to going into the shortcut list.
        ie- select what the script requires you to select prior to activating the script.
        dotdotdot
        • halroachH Offline
          halroach
          How can I do this?
          Thanks!!
          Thanks! that worked!
          come to think of it, it's the same when you want to assign a shortcut for flipping along axis of components!
