    [Plugin] Export 2d with Alpha
    148 Posts 42 Posters 143.9k Views 42 Watching
    • thomthomT
      Overview
      Exports the current view with transparent background option (SU8) if you use the PNG format. Will also let you export only what is displayed on your screen - where SketchUp's native Export 2D function would export the whole model, regardless.
      Access
      View > Export 2D
      Usage
      Export with transparency also works under Windows.
      Requirements
      • SketchUp 7 or newer - ( Other versions untested )
      • TT_Lib2
      404 Not Found
      (sketchucation.com)
      Footprint
      http://forums.sketchucation.com/download/file.php?id=53762
      <Sketchup>/Plugins/
      http://forums.sketchucation.com/download/file.php?id=53763
      tt_export.rb
      http://forums.sketchucation.com/download/file.php?id=53761
      • B
        Ben Ritter
        Thomas, thank you once again and happy Monday.
        • PixeroP
          Pixero
          Thanks, but I'm curious...how does it work?
          Was transparency there all along but the built in exporter couldn't handle it?
          πŸ˜•
          • JClementsJ
            JClements
            Thomas, this is great. I use the transparent PNG format for most all of my work so I can do compositing.
            A few weeks ago I had to make a 4' x 3' poster. Layout couldn't export the PNG because, I think because of the all the textures I had combined with the anti-aliasing of LayOut's export filter). My old workaround was to make all layers Black and then turn on color by layer to produce a black and white mask for an Alpha Channel but that doesn't work with textures that are comprised of transparent PNGs. Hopefully, this script will address these type of textures.
            This could be script my workaround for transparent PNG's. I will give it a test.
            Thank you !
            [Edit] P.S. I am going to change the name, however, to "tt_eportPNG.rb" ... incase you come up with some other export options
            • JClementsJ
              JClements
              Thomas, so far so good. I exported a 4,000 x 2,000 pix file no problem. I haven't tried using sketchy edge styles with it yet.
              Q- Would it be possible to read the aspect ratio of the users model window and give that as an option in your dropdown list?
              If you'd like a model to do tests with I can arrange to send one that could push the script to it's limits. Let me know.
              • thomthomT
                Added with the SU8 API.
                I can read the aspect ratio - but I can't make the values in the inputbox interactively change. I'd have to make a webdialog for that.
                I really have no control over what it can export. It simply calls the SU API: view.write_image - so I'm not doing anything different from what SU does - because it's all SU.
                • CadFatherC
                  CadFather
                  Master Thom Thom strikes again! 😲 (a true gem)
                  now i know why the name: it's two of you!! thank you, thank you
                  • JClementsJ
                    JClements
                    Thomas, if you could just display the aspect ratio that would be helpful. I could manually enter values using a calculator.
                    John
                    • EscapeArtistE
                      EscapeArtist
                      Great! I needed something like this last week, how did you know?
                      Thanks for another useful plugin! πŸ‘
                      • thomthomT
                        John
                        I'll see what I can do. I am currently working on a system to make advanced inputboxes easier to make.
                        • JClementsJ
                          JClements
                          Thomas. Not urgent by any means.
                          • PixeroP
                            Pixero
                            @thomthom said:
                            β€’SketchUp 7 or newer
                            So...how do I get this to work with SU 7.1?
                            It exports without transparency and always the whole model.
                            • thomthomT
                              Transparency? You can't.
                              hmm, not on my machine - remember to Hide Rest of Model. WYSIWYG.
                              • R
                                rv1974
                                Is there some way to separate shadows pass?
                                • PixeroP
                                  Pixero
                                  @thomthom said:
                                  • thomthomT
                                    No - I have no control of how it's generated. As you see from the sample I posted the shadows even comes from the whole model, not just what is visible.
                                    • PixeroP
                                      Pixero
                                      This can help for a shadow pass: http://rhin.crai.archi.fr/RubyLibraryDepot/download.php?file=displaytemplate.rb
                                      And maybe a modification of my Shadow control script (http://www.pixero.com/downloads_sketchup.html) could be made to set everything not selected to: e.casts_shadows = false
                                      • A
                                        archworks
                                        Congratulations - one of the best for su 2d app
                                        • GaieusG
                                          Hey, I did not see this, great plugin, thanks Thom! πŸ‘ πŸ‘ πŸ‘
                                          Edit; to me, it does not export with transparent background... Nor does it export only the active context. 😞
                                          • thomthomT
                                            What version of SU did you use?
                                            Got a screencapture?
                                            • 6
                                            • 7
                                            • 8
                                            • 1 / 8
