    [Plugin] Export 2d with Alpha
    148 Posts 42 Posters 143.9k Views 42 Watching
    • JClementsJ
      JClements
      Thomas, if you could just display the aspect ratio that would be helpful. I could manually enter values using a calculator.
      John
      • EscapeArtistE
        EscapeArtist
        Great! I needed something like this last week, how did you know?
        Thanks for another useful plugin! πŸ‘
          John
          I'll see what I can do. I am currently working on a system to make advanced inputboxes easier to make.
          • JClementsJ
            JClements
            Thomas. Not urgent by any means.
            • PixeroP
              Pixero
              @thomthom said:
              β€’SketchUp 7 or newer
              @thomthom said:
              Added with the SU8 API.
              So...how do I get this to work with SU 7.1?
              It exports without transparency and always the whole model.
                Transparency? You can't.
                hmm, not on my machine - remember to Hide Rest of Model. WYSIWYG.
                  rv1974
                  Is there some way to separate shadows pass?
                  • PixeroP
                    Pixero
                    @thomthom said:
                      No - I have no control of how it's generated. As you see from the sample I posted the shadows even comes from the whole model, not just what is visible.
                      • PixeroP
                        Pixero
                        This can help for a shadow pass: http://rhin.crai.archi.fr/RubyLibraryDepot/download.php?file=displaytemplate.rb
                        And maybe a modification of my Shadow control script (http://www.pixero.com/downloads_sketchup.html) could be made to set everything not selected to: e.casts_shadows = false
                          archworks
                          Congratulations - one of the best for su 2d app
                          • GaieusG
                            Hey, I did not see this, great plugin, thanks Thom! πŸ‘ πŸ‘ πŸ‘
                            Edit; to me, it does not export with transparent background... Nor does it export only the active context. 😞
                              What version of SU did you use?
                              Got a screencapture?
                              • HumpmetwiceH
                                Humpmetwice
                                Have I put something in the wrong spot or something cause when I go to view/export 2D the settings comes up but then it doesn't give me a file type to save it as?
                                  After the Settings window and you click OK you should get a File Dialog asking you what name to give the file. You must specify the file extension yourself.
                                  • HumpmetwiceH
                                    Humpmetwice
                                    I know and it doesn't give me any file type to save it as at all.
                                      You have to type the file type yourself - there is no list of file types because the SketchUp Ruby API doesn't let me provide one.
                                      So if you want to save a jpg file just enter "myfile.jpg" in the file dialog.
                                      • GaieusG
                                        The most recent one; SU 8.
                                        Here is a screen capture; now with a different codec than the one you could not open the other day if you remember...
                                        test2.avi
                                          That baffles me. I have no idea why this happens. Exactly the same works for me... ❓ πŸ˜• ❓
                                          test1.zip
                                          • GaieusG
                                            Well, sigh... I can always use LO for exporting png's with transparent background...
                                            Maybe it's an XP thing?
                                            • 1 / 8
