    Add a group to another group by rupy-code
    3 Posts 3 Posters 385 Views 3 Watching
      Andreas
      I would like to insert "Group1" into "Group2" by ruby-code.
      What should I do to make this work?
      With best regards from Germany
      Andreas
        Lets call them group1 and group2
        They must be in the same 'context'.
        You then use a newly made temporary group to contain both groups and manipulate all of the three groups as needed...
        context = group1.parent ### e.g. 'model'
        group_temp = context.entities.add_group(group1, group2)
        ### now transfer all group1's properties to group_temp
        ### you can skip those that are definitely not needed for YOUR groups...
        group_temp.name = group1.name
        group_temp.description = group1.description
        group_temp.layer = group1.layer
        group_temp.material = group1.material
        group_temp.hidden = group1.hidden?
        group_temp.visible = group1.visible?
        group_temp.locked = group1.locked?
        group_temp.casts_shadows = group1.casts_shadows?
        group_temp.receives_shadows = group1.receives_shadows?
        group_temp.glued_to = group1.glued_to
        attrdicts=group1.attribute_dictionaries
        attrdicts.each{|attrdict|
          name = attrdict.name
          attrdict.each_pair{|key,value|newMat.set_attribute(name,key,value)}
        }if attrdicts
        ### Note; if 'group1' HAD "observers" you now need to add them to 'group_temp' too...
        group1.explode
        ### this puts the 'group1.entities' at the correct 'level' in the new container.
        ### IF you want group2's entities 'loose', rather than as the group itself,
        ### then add 'group2.explode' too...
        group1 = group_temp
        ### 'group1' now refers to the 'combined group'
        ### that now includes the original 'group1.entities' AND 'group2'...
        ### or 'group2.entities' if you exploded it too.
          @andreas said:
          Are you talking about existing groups? If so, refer to TIGs post.
          If you are creating new groups via Ruby:
          group1 = model.active_entities.add_group group2 = group1.entities.add_group
