    Default save as v7?
    12 Posts 5 Posters 1.4k Views 5 Watching
    • PixeroP Offline
      Pixero
      Posted this in another thread but maybe it belongs here:
      Is there a way to set SU8 to save as SU7 by default thrugh ruby?
      (Like how I can set MS Word 2007 to save as MS Word 2003 by default.)
      Needed if several users work together and don't have the same version.
        Morgan74
        Hello,
        Sorry, but I think we can't do that because the Model.save method haven't option to set the SU version you want.
        http://code.google.com/intl/fr-FR/apis/sketchup/docs/ourdoc/model.html#save
        Bye
        • PixeroP Offline
          Pixero
          That means I'll have to continue with SU7 until SU has some features that can convince my boss to upgrade for all of us.
          • Dan RathbunD Offline
            Dan Rathbun
            Sketchup.active_model.method('save').arity returns 1 for the argument count, which is the save filename pathstring.
            I'm not here much anymore.
              Dan Rathbun
              ... and model.export does not work with a .skp file extension.
              • PixeroP Offline
                Pixero
                Would you care to explain? 😳
                IS there a way of saving as SU7?
                  Nope.
                    @dan rathbun said:
                    The arity method tells us how many arguments a method has.
                    Does it work for methods implemented in C?
                      Dan Rathbun
                      Well... since Ruby's internal methods are written in C, check this out:
                      Varible number of args:
                      Object.method('instance_eval').arity
                      -1
                      No args:
                      Object.method('id').arity
                      One arg:
                      Object.method('method').arity
                      Two args:
                      Object.method('instance_variable_set').arity
                      ..and etc.
                        Dan Rathbun
                        Therefore the above call, shows us that no new arguments have been added in v8.
                        Not automatically... but you can do so manually, thru the Save As... dialog.
                        And there seems to be a bug (in SU8😞
                        Dir.chdir( File.dirname( Sketchup.active_model.path ) ) Sketchup.active_model.save( File.basename(Sketchup.active_model.path) )
                        Does NOT save the model AT ALL in ANY version, regardless of what version the file is, or whether or not it has been modified, BUT stills returns true !
                        • PixeroP Offline
                          Pixero
                          Sorry for bringing this up again, but if I save as SU7 in SU8 and then after that press Save.
                          Will that continue to be a SU7 version or will it overwrite it back to SU8?
                            If you are working in a model that's been opened in 'v8' then whenever you 'save' it will be as in the 'v8' format.
                            Whenever you use 'save_as' it will be saved in the 'selected format' at the point you press OK: this defaults to 'v8' format every time: so you have to change it manually each time to another earlier version format - e.g. 'v7'...
                            Sorry, but your "dream" hasn't / won't come true... 😞
