    Updating in Layout 3
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    16 Posts 6 Posters 15.0k Views 6 Watching
    • R
      richyrich33
      Hi there,
      Cheers on the recent releasee of SU8, the new tools will definitely help in my workflow. I've just been having a wee bit of a problem with sending to Layout and updating/ changing scenes in there. Sending to layout works fine if Layout is closed but will not work if it is already open. The main problem is that once my model is in Layout 3 it won't change the scenes or update reference when need be (exclamation mark pops up in bottom right). The only way I've found to get around this is to double click each view (scene) that I've setup that will then change/ update accordingly. Originally I thought it was an issue bringing SU7 models into 8 and then sending to Layout though after creating a model in SU8 and sending it off it would do just the same.
      I've included a couple snaps outta sketchup. At thew moment I've been sticking with SU7 until there is a remedy for this problem. Has this been an issue for anyone else?? Any ideas on how to sort it out?
      Cheers
      When I try to change scene or update
      Double click remedy
      • sketch3d.deS
        sketch3d.de
        a customer of us has reported this too.
        Norbert
        • bmikeB
          bmike
          Is this your workflow?
          1. You are working on a SketchUp model and LayOut file simultaneously.
          2. You make changes in the model and save it.
          3. When you go back to LayOut you see the warning symbols that the model has changed?
          Does this behavior happen if update the entire LayOut drawing by using File>Document Setup>References?
          mike beganyi design + consulting llc
          • J
            jhauswirth
            Auto render is turned off, turn it on, or select the model and click render.
            • D
              d12dozr
              I have this problem too, is it possible to "Send to Layout" when LO is already open?
              http://goo.gl/f7ooYh
              • bmikeB
                bmike
                are you sending the same model that is already linked to your LO file? are a different one?
                • D
                  d12dozr
                  A different one...like this:
                  -I am working on a LO file
                  -I finish and close that file, but do not close LO
                  -I open a new file in SU, hit "Send to Layout"
                  -Nothing happens, so I close LO, then hit "Send to Layout" from SU and then the file opens in LO
                  • B
                    bjanzen
                    Yes. This is a known issue on Windows. When you launch both apps, if you "Run as Administrator" it'll work.
                    b
                    • D
                      d12dozr
                      Ok, thanks Barry.
                      • R
                        richyrich33
                        Hi there,
                        Cheers for your replies and feedback, I'll have a good look at this tonight when I have the time and get back with some feedback
                        • R
                          richyrich33
                          Sweet, yes the auto render under Layout Preferences/ General/.. worked wonders
                          Thanks J Hauswirth 😍
                          • R
                            richyrich33
                            b
                            Yeah tested this by sending one model to LO, then made new one saved and tried sending, no luck. My user account is an administrator, well, the only admin on this comp. Using vista home premium SP2, not sure if this is an issue...
                            Cheers again
                            • bmikeB
                              bmike
                              b
                              Cheers again
                              Pretty sure you still need to tell the program to run as admin...
                              If you right click on the .exe icon to launch, you can get to a check box under advanced.
                              This should keep the setting so you do not have to right click each time.
                              • J
                                jhauswirth
                                The checkbox on the SketchUp dialog called Auto also changes this setting.
                                • R
                                  richyrich33
                                  Aa yes yes yes, my bad for not exploring all the functions in the dialogue boxes, even in SU7. When I made the transition to SU8 it had changed a few settings that I wasn't use to manipulating, now I have been shown the light! cheers again mate.
                                  Auto Render
                                  • R
                                    richyrich33
                                    @bmike said:
                                    b
                                    Cheers again
                                    Ha yeah that did the trick, learn something new everyday πŸ˜„
                                    Thanks bud
