    Thea Render - Interactive Rendering
    extensions
    146 Posts 23 Posters 47.7k Views 23 Watching
    • EarthMoverE Offline
      EarthMover
      Pete, I think he's asking if you can control the position and look of the HDRI image within Thea, or did you do it externally. Probably because of the seamless way that the tonal qualities match between the IBL and the Geometry. Also the CFR in there is helping sell the illusion that it's all one photograph. Hard to achieve that in other engines.
      Stunning render...I must say!! 👍 👍
      Content Creator at Skapeup
      • soloS Offline
        solo
        Ah, yes and yes.
        You can move the HDRi around as well as camera and objects, then as mentioned using CRF's you can pretty much blend them like I did above.
        http://www.solos-art.com
        • simon le bonS Offline
          simon le bon
          @Earthmover, 😉
          thanks! , You have perfectly translated my interrogations 👍=
          @Solo
          @solo said:
          Ah, yes and yes.
          How do you import this HDRI into a Thea scene? I have searched this option without find it.
          And also: Is it possible to include a HDRI into a SketchUp model and export the model into Thea?
          Very simple questions, sorry for disturbing..
          ++simon
            At the top right, go to Environment > IBL (Image Based Lighting I presume). Enable the feature you want (there are options to open different resolution images of the same file for performance reasons) and import your hdr image.
            If you are not planning to do any fancy stuff, Background mapping is enough (that should be a full resolution image however). For simple reflections in windows for instance, you may also wish to enable the reflection channel at least if I am not mistaken.
            • soloS Offline
              solo
              here
                simon le bon
                Thank you sirs!! 👍 😎
                • N Offline
                  notareal
                  Thea Render RV425 Beta1.6.3 is available. Interactive render is now much faster when tweaking image-based lighting settings (IBL panel), also some network rendering & packing related bugs are fixed.
                  Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                    Already downloaded!
                    (and first time ever used an own model to post a note in TDC 😉 )
                    • N Offline
                      notareal
                      Thea Render RV446 Beta1.7.1 is available (dev forums, registration required. Available in few days from public download).
                      There been some hard developing work for this release. With recent technical advances Thea Render will give you; region rendering, improved efficiency of unbiased TR1 engine, ambient occlusion support (with dirt mapping) for BSD and the terminator artifact treatment.
                      Terminator artifact treatment is quite important for users that do relay on low polygon models.
                      Terminator shading artifacts, common for unbiased rendering and low polygon models
                      Thea Render RV446 produces perfect/smooth shading, artifact-free.
                      RV446 also contains numerous bug fixes (Changes Log).
                      • daleD Offline
                        dale
                        Another killer upgrade. I can't believe what you folks have done to Thea during beta.
                        Cudo's, and thanks so much.
                          Don't forget to mention the enhanced TR1 rendering with interiors, Notareal! That is also a very valuable improvement (and of course, region rendering!!!)
                          • Chris FullmerC Offline
                            Ooh, I had not noticed the ambient occlusion and dirt map before.....those sound fun! Thanks for the heads up. Its downloading now.
                            Chris
                            All my Plugins I've written
                            • N Offline
                              notareal
                              Chris
                              AO & Dirt map are under development, so just some basic features are now available. Some discussion at http://www.thearender.com/forum/viewtopic.php?f=54&t=4365
                              • N Offline
                                notareal
                                I think I mentioned "improved efficiency of unbiased TR1 engine", but true... it's worth to emphasis; TR1 did got a serious boost, some scenes gained about 100% speed increase. It's almost like a dual core laptop jumped to quad. You may read about improvement of TR1 unbiased engine here: http://www.thearender.com/forum/viewtopic.php?f=17&t=4262
                                (pop image open for animation and compare shadow areas)
                                Animated gif showing renders of TR1 and TR1+ (as new enhanced TR1). Scene rendered by Pete Stoppel.
                                  Sorry, indeed you did. Sigh... That was 4:19 a.m. here (without sleeping the night before...)
                                  • N Offline
                                    notareal
                                    Thea Render Beta 1.7.2 Revision 451 is released at the Thea development forum. In this revision, you will mostly find some fixes regarding animation setup. The rotation interpolation scheme has been replaced with a new one that is much more consistent when interpolating key frames. In addition to that, you can now click and drag the key frames (from the small handles on the top of the lines) having more control on the setup. There are also some network rendering improvements.
                                      simon le bon
                                      Hi Dear Pentti,
                                      All these new improvements sound very attractive (appreciate those focused on "network"). Thea Render brings together a wonderful team, really 👍 👍
                                      Important note: the revision posted here is the latest development snapshot. To stay on the safe side, it is recommended to wait until some basic testing is made and version is accessible from our web site downloads section.
                                      Do you think we can install this new release right now ?
                                      Cheers,
                                      simon.
                                        Will animation rendering work now? Mine always skips frames. If I can't get it to work, I'll take the issue over to the Thea forum.
                                        • N Offline
                                          notareal
                                          Cheers,
                                          simon.
                                          There is a little IES related bug in the new RV, that should be fixed when new release is added on public download at http://www.thearender.com/cms/index.php/downloads/thea-render.html If you are using IES, it might be worth to wait for the public release - it should be available in few days.
                                          @Chris, have you made a bug report? There are several bug fixes for animation and key-frames, so it may be fixed, give it a try.
                                            I've got the new one downloading now. I'll give it a try and see if my animation works better. I was reading through the release notes and saw this one:
                                            Fixed case when a late client was contributing a "ghost" image for a previous render. (network)
                                            YES!!! That has come back to bite me so many times.... Glad to see its fixed. I'll test it later tonight I think.
                                            I don't think I've really said how much I enjoy Thea. Glad my company invested in it,
                                            Chris
                                            • 6
                                            • 7
                                            • 8
                                            • 2 / 8
