    Reading external files
    8 Posts 3 Posters 653 Views 3 Watching
    • honoluludesktopH Offline
      honoluludesktop
      chosen_file is a external file. I would like to search the chosen_file line by line for "XXXX", then save the next line in the data array. How do I increment the read file pointer to the next line?
      aFile = File.open(chosen_file, "r")
      Data = []
      #Search each line for "XXXX"
      aFile.each_line do |line|
        If line == "XXXX" #if found
          #How do I get next_line, to save to Data
          Data.push next_line
      aFile.close
        aFile.read_line ?
          honoluludesktop
          The following generates error message:
          undefined method โ€˜read_lineโ€™ for #<File:C:TEST.DAT>
              aFile.read_line
          aFile.close
          • Didier BurD Offline
            Didier Bur
            array_of_lines=IO.readlines(chosen_file)
            Will let you do what you want, line by line or not, no pointer, no nothing ๐Ÿ˜Ž
            DB
              honoluludesktop
              Didier, Thanks. I will try that when I go to the office later today ๐Ÿ™‚
                honoluludesktop
                Well, that created an array of the whole file. Can I just get the next (n) line? I can do it with a counter as attached, but the code gets complicated when searching for many different line descriptions.
                SaveIt = []
                count = 0
                line_location = -1
                  count = count + 1
                  if line == "xxxx"
                    #calculate the location of the next line
                    line_location = count + 1
                    #test if location and current line match
                    else if line_location == count
                       SaveIt.push line
                aFile.close
                  Didier Bur
                  saveIt = []
                  skipNext=false
                  0.upto(array_of_lines.length-1) { |i|
                    if line[i] == "xxxx" and !skipNext
                      saveIt.push(array_of_lines[i+1])
                      skipNext=true
                    else
                      skipNext=false
                  DB
                    honoluludesktop
                    :-0....now I get it, thanks.
