    Creating an even grid of perforations on a curved object
    6 Posts 3 Posters 4.7k Views 3 Watching
    • K Offline
      kylebc86
      Hi guys,
      I am just wondering if anyone could help me. I am trying to create an even grid of perforations/openings on a organic curved object in Sketchup. Heres is an example of how i want it to look like. I want the openings to be of similar size all the way round the object. I have tried to drape the shape of the opening on the object, however when it comes to the curved corners, the shape of the opening becomes distorted and nothing like the original shape I am trying to achieve. Thanks in advance for your help.
      Kyle
      • jeff hammondJ Offline
        jeff hammond
        here's the first idea that popped in my head and i'm sure there are other ways..
        this technique revolves around chris fullmer's plugin- component onto faces:
        http://forums.sketchucation.com/viewtopic.php?t=17306
        (it's actually similar to your drape idea except this will make your shape more perpendicular to the surface that you're trying to project to..)
        i just rushed through the video without paying much attention to anything but hopefully the idea comes through and you'll be able to adapt it to your needs.
        [flash=660,405:346nxcow]http://www.youtube.com/v/mqBHiakyrEQ?fs=1&hl=en_US&rel=0&color1=0x2b405b&color2=0x6b8ab6&border=1[/flash:346nxcow]
        also, maybe look into tools on surface by fredo:
        http://forums.sketchucation.com/viewtopic.php?t=11212
        it might be a bit difficult getting the rounded edges in the cutouts with that one though.
        if you have a lot of stuff like this to do, maybe a little bribe to fredo could get him to add rounded rectangles/parallelograms to TOS πŸ˜„
        dotdotdot
        • K Offline
          kylebc86
          Hi Jeff,
          Thank you very much for the reply and the useful information. I will look into this, seems like a better way to achieve what i want than what i was attempting to do. I will have a play about with the ideas you have on how i could achieve this. Thanks again
          By the way, do you know what the plugin called that is used to create the wiggly line in the video??
            jeff hammond
            of course.. it's called Draw_Wiggly_Line.rb πŸ˜„
            ok, sorry
            that's part of fredo's BezierSpline plugin found here:
            http://forums.sketchucation.com/viewtopic.php?t=13563
            i was using Uniform B-splines in the video
            dotdotdot
              joebamber
              I have been trying to think how you could do this one... only way i could see it happening is by unfolding the surface, applying the regular component spray/shape and then re-folding the surface back up, if it were possible; you could then make any number of patterns across a 2D mesh or component spray across a 3D mesh - once it had been refolded, which would be a very nice ruby for mesh designs to be cut at certain points - and designing buildings like *the eden project's geodesic domes would become easy.
              • K Offline
                kylebc86
                Thanks for that Jeff.
                Joebamber, I was thinking that unfolding the surface would be a way of achieveing this. Is there a plugin that will allow the surface to be unfolded, even on curved and organic shaped objects?
                Thanks for your help
                Kyle
