    [Plugin] Architect Tools
    119 Posts 32 Posters 164.1k Views 32 Watching
      The plugin formerly known as Plan Tools
      Overview
      Selection of snippets I've written while working on DWG imported data. They are specially made for my workflow and is not always the most user friendly. Beware.
      YouTube playlist of demonstration of features: http://www.youtube.com/playlist?list=PL6Rzx3v8Zm9ab5fgTskg9oXFUqJHgB-Z4
      Access
      Plugins > Architect Tools
      Features
      Generate Buildings
      Enter a comma or pipe separated list of layer which contains building boundary data.
      These lines are then projected down to ground level and attempted to form faces which is extruded back up to the lowest/highest point above.
      Quick and dirty tool to get the bulk work done when importing DWG site plans.
      [flash=640,385:1iox3vzi]http://www.youtube.com/v/USPmnHyksIQ?fs=1&hl=en_U[/flash:1iox3vzi]
      Merge Solid Buildings (2.0.0)
      Merge solids but keep edges on top of the objects. This is so one can later detail the roofs for building generated with the "Generated Buildings" feature. (Video coming)
      Fill Solid Holes (2.0.0)
      Attempts to remove all holes in solid objects. Like window holes in a wall.
      Select Non-Solids (2.0.0)
      Filters down the current selection to only non-solid groups or components.
      Make 2:1 Road Profile
      For each selected edge two triangle are formed at either end of the edge making up for a road profile of 2:1.
      Move to Z (2.0.0)
      Allows you to set the Z height of selected edges. Made for creating roads where you have Z height given for sections along the road. (Video coming)
      Contour Tool (2.0.0)
      Tool to assist in closing up contour curves from CAD drawings where not all contours are properly closed. (Video coming)
      Extrude Up (2.0.0)
      Once the contours for a terrain has been created on a flat plane, with faces, this function will attempt to extrude the faces up to guiding 3D contour lines above. (Video coming)
      Project Down Tool (2.0.0)
      Tool that let the user pick edges in a group/component, without opening it, and it will be projected down to the first face underneath it. Intended to project roof edges down to building volumes underneath for later detailing. (Video coming)
      Magnet Tool (2.0.0)
      Pick edges that will be projected upwards until it hits other geometry. Intended to pull roof feature lines up to guiding 3D edges above. (Video coming)
      Move to Plane (2.0.0)
      Tool written to assist in adjusting surfaces to lie on a picked plane. (Video coming)
      Flatten Selection
      Flattens the selection (recursively) to Z level 0
      Crop Selection to Boundary
      1. Select a face parallel to the ground plane.
      2. Select a group/component with edges to crop
      3. Run the command
      http://forums.sketchucation.com/download/file.php?id=53776
      All components inside the selection will be made unique!
      [flash=640,385:1iox3vzi]http://www.youtube.com/v/1UOZ2IxDhfA?fs=1&hl=en_US[/flash:1iox3vzi]
      Put Geometry on Layer0
      Puts all Faces and Edges on to Layer0
      Grid Divide
      Splits the edges in the selection by a given grid size.
      Requirements
      • SketchUp 7 or newer - ( Other versions untested )
      • TT_Lib2 (2.7.0)
      Guide: How to install RBZ Files
      http://sketchucation.com/pluginstore?pln=tt_architect_tools
      Footprint
      http://forums.sketchucation.com/download/file.php?id=53762
      <Sketchup>/Plugins/
      http://forums.sketchucation.com/download/file.php?id=53763
      tt_architect_tools.rb
      http://forums.sketchucation.com/download/file.php?id=53761
        DIEGO-RODRIGUEZ
        thanks thom. exelentes tools.
        a question.
        Plant when I run the tool tools> Flatten selection, are exploited all the curves and circles.
        may not exploit the arcs and circles?
        thanks
          is your question why curves and arcs is exploded when flattened?
          it's because SU applies geometric restrictions to transforming an arc's vertices.
          I suppose arcs might be preserved if the arc is parallel to the ground.
          • P Offline
            Panga
            Damn ! All your last rubies'll boot my workflow ! Thanks for sharing your tools.
            Regards.
              Version 1.1.0
              • Grid Divide
                Version 1.2.0
                • Bug fixes
                • Improvement to the Generate Building feature. Does a lot more work to extract usable data when generating the buildings.
                Make sure to update TT_Lib2
                I wanted to make a toolbar for this plugin, but I have so many thing to do that I'll have to wait for a later release. Sorry.
                  rv1974
                  It contains the best flattening routine in SU! Thank you!
                  Bugs:
                  If I take some vanilla line and try to 'grid dividing' I get a runtime error in line:29 (expected identifier,string or number).
                  P.S. + Error in line 9 (UI is undefined)
                  P.P.S. Apparently 'grid dividing' executes itself twice. In attachment, I just extruded the result of zigzag dividing.
                    blajnov
                    @thomthom said:
                    @blajnov said:
                    Thank you very much for the update, but downloading SketchUP Pro v.8, an error ...
                    That refers to Plan Tools...
                    Can you open the Ruby Console and type in load 'tt_plan_tools.rb' ? Post back the whole message. (In the Plan Tools thread please.)
                    Ruby Console....
                    C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_plan_tools.rb:34: warning: already initialized constant VERSION
                    C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_plan_tools.rb:35: warning: already initialized constant PREF_KEY
                    Error: #<SyntaxError: (eval):35:in read_default': (eval):35:in read_default': compile error
                    (eval):35: unterminated string meets end of file>
                    (eval):2537
                    C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/settings.rb:48:in []' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/settings.rb:88:in set_default'
                    C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_plan_tools.rb:43
                    (eval):2537:in `load'
                    (eval):2537
                      hm.. I'll have a look at it later today. Thanks for reporting.
                        Ruby Console....
                        (eval):2537
                        (eval):2537
                        What is the size of the 'tt_plan_tools.rb' file you got? From the error it seems that it's truncated at line 43...
                          blajnov
                          Filesize tt_plan_tools.rb 20.4Kb
                            hm.. I don't understand this error. I can not reproduce it at all.
                            I wonder if the file has become corrupted. Can you send the the file you have?
                            Also, what is the OS and SketchUp version you use?
                              blajnov
                              OS Windows 7 x64, Google SketchUp Pro 8.0.4811
                              File:
                              tt_plan_tools.rb
                                That's the same Windows and SU version I use. I do not comprehend at all why you get that error.
                                Can you post a screenshot of your plugins folder? and thre TT_Lib2 folder?
                                  blajnov
                                    Is that the full error message?
                                    From SketchUp or the Webdialog? Again, is it the full error message?
                                      Oh, it's the same error Dave reported in CleanUp. Gotcha.
                                        What version of IE do you have installed?
                                          @blajnov: I really have no idea why you get those errors. Though your SketchUp folder looks odd. lots of other plugins folders. (but that might not mean much..)
                                          I can't read the language your OS is in, but is there anything in the Explorer window that says something like "Compatibility Files" when you're in the plugins folder?
                                            rv1974: I've installed XP Mode and tried it out on a virtual PC with IE7 and I see the error. Seems to be an issue with IE7 and older. Will look into it next week.
                                            • 6
                                            • 1 / 6
