    [Plugin] Solid Inspector
    303 Posts 99 Posters 342.4k Views 98 Watching
      driven
      hi Thom,
      I've turned on 'BackEdges', coloured the enclosed faces and added a section plane to highlight 'enclosed faces', could this be added..... or maybe highlight enclosed edges, as deleting these is the remedy....
      just some thoughts while testing.
      btw, the return key as well as tab scrolls thru your views on the mac and getting back to the select tool doesn't work with the space bar when using...
      keep up the good work
      john
      could this be auto generated within the script?
        I avoided using material as I didn't want to clutter people's models. Removing materials requires some akward workarounds and I didn't want to get into that. Section planes are the same, need to apply some silly hack to add them to the scene ... and I don't think one can even activate them via Ruby. ๐Ÿ˜ž
        It should be highlighting the edges though, while the tool is active. you're not seeing that?
        Yes, Tab and Return allows you to navigate to the various areas (I want to make a UI for that.) though it should not be interfering with the Space key at all. I have no problems using it while I use the tool. ... ??
          driven
          fair point, but what about using a 'style' set,that's purged when your done?
          @thomthom said:
          Section planes....(edit) I don't think one can even activate them via Ruby. ๐Ÿ˜ž
          it seems to me that the api lets you, but I'm no coder...
          sorry, it is highlighting the multi-face edges, it's the enclosed/internal (to volume) edges I was wondering about
          I'm just airing ideas 'for that', I've tested/used all the pre-existing repair-aid scripts (TIG's,VW,CadSpan,etc.) and currently use bits from each, in a rather untidy workflow.
          we stop for Xmas next week and I'll try and organise my thoughts a bit better,
          I like what you've done with this so far...
          john
            The API only let you get and set the position of section planes. No way to add or activate them. ๐Ÿ˜ž
            Oh, detect geometry inside solids. hmm... Not quite sure how one would do that... It's a thinker...
            The problem is that one can't assign a style to just a small set of edges - it#s all or nothing.
            But, with a new UI one could possibly have a checkbox that would toggle whether the invalid geometry is marked with a material.
            • G Offline
              GWD
              john
              John, did you already test my new fixSolid? http://forums.sketchucation.com/viewtopic.php?f=323&t=33471
              Guy
              • E Offline
                eliasandraos
                Lots of time saved. Thanks so much.
                • jason_marantoJ Offline
                  jason_maranto
                  I just wanted to say this is the best plugin ever -- I find myself using some plugins every once in a while and a few very frequently, but this plugin instantly became something I used 20-30 times a session.
                  Thank-you sooooo much for making this -- I didn't think I needed it but it has saved me dozens of hours already in just a few weeks... why they would include the solids tools in 8 without including this function I don't know but for me it is now an essential tool.
                  Best,
                  Jason.
                    ๐Ÿ˜„ cheers!
                    As I've begun to use the Solid Tools in SU8 more and more I find myself relying on it more often. And I found that I need to allow it to work within the group, component one wants to fix. As going out of the group your fixing to inspect it is just too awkward.
                    • jgbJ Offline
                      jgb
                      I've been using Solid Inspector for about 3 weeks now, and only a few days ago discovered the <tab> key, arrow key and <enter> functions. Never thought to look down. ๐Ÿ˜ฎ
                      I use it so much I have the "S" key as a shortcut. ๐Ÿ‘
                      But a most unintuitive aspect of SI is when it finds and highlights the problem(s). ๐Ÿ‘Ž
                      Generally you want to delete the offender entity(s).
                      The process is to toggle amongst the highlights to choose one, which is now indicated by a red circle. โ—
                      Press <Enter> to zoom in on it.
                      Place the white arrow cursor on the highlighted entity.
                      Right click and select "Edit group". If you click "erase" here, it will delete the whole group.
                      Keeping the cursor on the highlighted entity, Right Click and select "erase". That will delete the single cursor-ed entity only. Either 1 line or 1 face, but not the faces highlighted perimeter lines.
                      And that leaves you in a form of limbo. ๐ŸŽ‰
                      Now you have to select the "edit menu" and "close group" to get back into SI for the next problem.
                      Since 99.9% of the time you want to simply delete the offending entity, why not simply;
                      Place the cursor on it and just double click to delete the red highlighted entity.
                      Then you toggle to the next.
                      This obviates the wish for an auto-fix which is complex and where a simple deletion may not be the fix one needs to do.
                      One other thing; when SI encounters a true solid (no errors) please say so, maybe a green circle around the group/comp. But do come out of the white arrow select mode.
                      jgb
                        Alencar
                        Dear Thomthom
                        is amazing how a simple program can solve such a complex issue and recurrent.
                        this is brilliant
                        thank you, very much.
                        • jgbJ Offline
                          jgb
                          @alencar said:
                          Dear Thomthom
                          this is brilliant
                          Believe me, Solid Inspector is not a "simple" program by a long shot. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                          TT has displayed an ongoing expertise in solving problems in SU that should have been an intrinsic part of SU from the get-go.
                          Using SI as a prime example; SU's attempt at being a solid modeler is commendable, however, to allow the tiniest errant fragment to prevent a solid from "forming" and NOT TELLING YOU WHY is amateurish at the least. ๐Ÿ‘Š
                          TT gets an A++++ for that fix.
                          jgb
                            Alencar
                            dear Thomthom
                            when I said "simple" I wanted to say that it was an easy program
                            to use, no less important.
                            "simplicity is characteristic of that is good"
                            sorry if not properly expressed
                            (I can not praise what is done well)
                            your plugin is fantastic.
                            Thanks.
                              I have plans (desire) to make the inspector work inside the active group/component instead of outside. That would improve usability.
                              • jgbJ Offline
                                jgb
                                Thomthom said "I have plans (desire) to......"
                                I know THAT feeling all too well. ๐Ÿ˜†
                                jgb
                                • mariochaM Offline
                                  mariocha
                                  That would sure be a great improvement
                                  on an already so useful plugin! ๐Ÿ‘ ๐Ÿ‘ (icon of your username)
                                  Now youv'e made me eager .
                                  %(#008000)[Mario C.
                                  • majidM Offline
                                    majid
                                    this was realllllly handy to me .... nowadays I was modeling a chair part , to be produced by plastic, and need to be a solid, and it was really handy.
                                    thanx a bunch.
                                    • E Offline
                                      ericschimel
                                      Nice work Thomas! I am going to check this out. I really hate trying to find small holes in groups!
                                      -Eric
                                      http://plugin.sketchthis.net
                                      Sketchup Kitchen Design Plugin
                                      Custom Models
                                      • K Offline
                                        Kev_Ov
                                        Thank you so much!!!
                                        Leaks had been bugging me for days!
                                        • E Offline
                                          emartingr
                                          Defects in solids are sometimes produced by carrying out SU boolean operations, and these are very difficult to find. SI is a most welcome tool. Thanks a lot!!
                                            d12dozr
                                            Thomthom, I use this plugin ALL the time...how do I send you a cookie?
                                            http://goo.gl/f7ooYh
                                            • 15
                                            • 16
                                            • 3 / 16
