    [Plugin] TT_Lib²
    310 Posts 66 Posters 436.9k Views 66 Watching
    • guanjinG Offline
      guanjin
      @guanjin said:
      @tt_su said:
      @guanjin said:
      2.9.4+Selection_Toys,In Sketchup8 windows XP, open the dialog, automatic sketchup8 quit after tens of seconds, without any prompting。
      That is strange. I cannot reproduce that. By the way, Selection Toys has never used TT_Lib2. I used TT_Lib1 for a while - but I made it stand-alone earlier this year. What version of Selection Toys do you have? And if you have only Selection Toys loading, does it still crash?
      @guanjin said:
      Edge Tools,Can not be used, loading errors。
      What are these loading errors? (I can't do much without them.) Also, what version of Edge Tools.
      Selection Toys loading2.36 Edition。
      [attachment=0:32tfbp3s]<!-- ia0 -->QQ图片20131211190130.jpg<!-- ia0 -->[/attachment:32tfbp3s]
      UV Toolkit v2.31
      Are not available。Earlier versions without problems。
      TT_Lib2 2.8No problem, you can normally use
      I come from China, is to learn
      • guanjinG Offline
        guanjin
        tt_selection_Tools ,In 2013 the working properly
        • tt_suT Offline
          tt_su
          I'm sorry, but I am a bit confused now. Which plugins work and which plugins doesn't work?
          Also, if there are error messages - what do they say?
          • guanjinG Offline
            guanjin
            1.tt_selection_Tools ,In sketchup8 Does not work,After opening the tool, sketchup automatically exit after a few seconds。
            • tt_suT Offline
              tt_su
              Hm. I'm unable to reproduce this. Maybe it happens only on XP. I have to ask someone to test for me.
              Does it happen if you have only Selection Toys installed?
              • guanjinG Offline
                guanjin
                Did not happen, but the old version 2.2 can be used normally
                • tt_suT Offline
                  tt_su
                  hm.. if you can load Selection Toys alone, but not with the rest of your plugins it sounds like a clash. Any chance you can find out which plugin it clashes with?
                  • guanjinG Offline
                    guanjin
                    Version 2.2 normal way? It will not conflict.
                    2.36 will flash back it?
                    • tt_suT Offline
                      tt_su
                      I'm sorry, but what do you mean by "flash back"?
                      • guanjinG Offline
                        guanjin
                        After opening tools, a few seconds sketchup8 automatically quit.
                        • tt_suT Offline
                          tt_su
                          But doesn't happen when it is the only plugin installed?
                          If it crashes when you have other plugins installed, can you find out which one that will make it crash?
                          • G Offline
                            g_wilson
                            Hi - Given the season - I feel like Alastair Sim haunted by the Ghost of Christmas Past dragging the chains of XP about. I loaded 2.3.6 Selection Toys - SU8 starts up - stays up - functions with no problems. All items in tool bar enabled. BTW => XP SP3 plus TT Library v2.9.4 plus I also have a gazillion plugins installed but none of the known troublemakers.
                            • irwanwrI Offline
                              irwanwr
                              @tt_su said:
                              irwanwr: did 2.9.4 fix the error message you where getting?
                              Nope. No error at all 😄
                              Selection Toys 2.3.6
                              Edge Tools 2.0.4
                              UV Toolkit 2.3.1
                              on Win XP SP3, IE 8.
                              • OxerO Offline
                                Oxer
                                Hi, I have a question, why does appear the TT_Lib² in Disabled Extensions on SketchUcation Extensions Manager window?
                                In SketchUcation Plugins Manager window it appears like Plugin Loaded (see the image below).
                                I select TT_Lib² on SketchUcation Extensions Manager window and I push the button Load-Permanently, I close the window and quit SU, then I restart SU but TT_Lib² appears in Disabled Extensions again.
                                http://www.oxervision.blogspot.com/
                                  When an Extension 'sticks' in the disabled [red] side of the Manager despite you trying to enable it, then it means that something is wrong with its code as it loads...
                                  Have you ever disabled this Lib ?
                                  Are you sure it is installed correctly ?
                                  Look at the files inside the Plugins folder.
                                  If they are named ending in .rb! they manually rename them as .rb and restart SketchUp.
                                  You should now see an error message.
                                  This might help resolve what is wrong.
                                  If you have FULL rights to your Plugins folder and have installed the very latest versions of the Lib and other related Plugins, then there should not be any odd behavior 😕
                                  • tt_suT Offline
                                    tt_su
                                    Maybe the PluginStore is confused over the root TT_Lib2.rb file. It implements SketchupExtension class - it it appear in the Window > Preferences > Extensions list. But unticking it won't disable TT_Lib2 because the plugins that use it load TT_Lib2/core.rb directly.
                                    I still don't know if that is the case though, I don't know what PluginStore is doing.
                                    When TT_Lib2 appear disabled in PluginStore - do the plugins that depend on it load?
                                      @TT - your Lib appears in the native Extensions panel and the SketchUcation Extensions Manager.
                                      But it fails to display details in the latter - I suspect because you've named it with a superscript 2 - because if I rename it with a normal 2 it works with details etc !
                                      So that is probably causing subtle issues - perhaps in js ?
                                      So I know how to probably fix the issue - I'm testing it shortly...
                                      Watch for v2.5.0 out soon...
                                      • tt_suT Offline
                                        tt_su
                                        Ah, an multi-byte character issue then.
                                          I now have it working with the superscript 2...
                                          • tt_suT Offline
                                            tt_su
                                            Thanks TIG!
                                            That superscript 2 has caught many off guard.
                                            http://tmfassociates.com/blog/wp-content/uploads/2011/03/monty-python-spanish-inquisition.jpg
                                            "Nobody expects Unicode multi-byte characters!"
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 12 / 16
