    Whats these code mean?
    4 Posts 3 Posters 457 Views 3 Watching
    • H Offline
      hebeijianke
      #requires face or faces within a selected group or number of groups
      require 'sketchup.rb'
      class Crack
      	def Crack;;groups
      	  # get the active model
      	  model = Sketchup.active_model
      	  #get currently selected objects
      	  selection_set = model.selection
      		cracks = 0
      		stepbystep = UI.messagebox "Exclude random faces from cracking?", MB_YESNOCANCEL, "Proceed"	#use to validate each face before its drawn
      		if stepbystep == 2
      			return nil
      		Sketchup.active_model.start_operation "Crack groups"
      		# loop through all the selected faces, and triangulate them
      		selection_set.each {|group|
      			#selection_set.remove group
      			if group.typename == "Group" then
      				maxcracks = group.entities.count * 2
      				group.entities.each {|entity|
      					if cracks > maxcracks then
      						return nil
      					entities = group.entities
      					if entity.typename == "Face" then #to crack a triangle
      						# get all the vertices for the current face
      						vertices = entity.vertices
      						# find the centroid - equals the average of all vertices, so lets add all coordinates together to divide it
      						centerx = 0
      						centery = 0
      						centerz = 0
      						0.upto(vertices.length-1) do |vert|
      							centerx = centerx + (vertices[vert].position[0]/vertices.length)
      							centery = centery + (vertices[vert].position[1]/vertices.length)
      							centerz = centerz + (vertices[vert].position[2]/vertices.length)
      						geomcen = Geom;;Point3d.new(centerx,centery,centerz)
      						#prepare the randomly excluded face crack
      						random_exclusion = rand(vertices.length-1)
      						# insert the edges
      						0.upto(vertices.length-1) do |vindex|
      							if vindex != random_exclusion or stepbystep == 7 then
      								edge = entities.add_edges geomcen,vertices[vindex]
      								cracks = cracks + 1
      		Sketchup.active_model.commit_operation
      	end #def
      end #class
      if( not $cracking_menu_loaded )
        UI.menu("Plugins").add_item("Polygon Cracking") { Crack.groups }
        Where did you get the code?
        It is unattributed...
        If the whole of the code were in a file called say CrackGroup.rb inside the Plugins folder then it would load.
        The code makes a class 'Crack' def 'group' that 'cracks' faces inside selected groups.
        It adds a new Plugins menu item [NB: it needs to declare the menu is loaded as a last line...] called 'Polygon Cracking'.
        This takes all faces [or all-random_few] in a selected group and 'cracks' them - i.e. if finds the face's center and draws extra edges out to vertices as if the face is 'cracked' [glass etc] - the number of 'cracks' is randomized to a limited extent but that is set to be the same on every face in the group [it could be made random for all of the faces ?].
        It runs its 'cracks' over any nested faces and any 'holes' or reentrant areas [e.g. with L's] in faces.
        It screws up its face divisions because it is written so it affects the very 'entities' it's iterating through and trips itself up - unless that's intentional it is readily fixed by using group.entities.to_a.each{... instead of group.entities.each{... so the added entities aren't considered in the set that's getting processed...
        What is it for ??
        • H Offline
          hebeijianke
          THX
          I got a plugin named Tooling
          It's in The Tooling file
          I upload it
          Tooling.rar
            Jim
            The code finds the geometric center of a Face, then adds some Edges from the center to the outside vertexes. "Crack" means break, shatter, fracture, subdivide.
