How to disable sounds - layer manager picks
New phenom: Getting dings and such when I make layer picks in the layer manager.
Don't want; pls. advise how to terminate.
Thank you.
Have you got housebuilder.rb installed?
Thanks, Gai... That was the culprit last time with context menu picks (previous thread: http://forums.sketchucation.com/viewtopic.php?f=79&t=27854), and thence removed... I looked for HB before I posted but will re-check to see if it is under a rock somewhere.
Yes, I do have it, but I thought it was the fixed version.
I'll look for the offending UI:beep or UI::beep.
Register LoginAdvertisement
