Wood Plank Trouble!
Hi everybody,
I'm working on texturing of models and having trouble with Wood Planks. Is it me or is it damn hard to find good textures of woodplanks? I use CGTextures a lot but it's hard to make them seamless. Pixplant has trouble with wood textures and a lot of other apps to. The offset method is also very time consuming and hard with wood textures. I also tried to model teh woodplanks and texture them with a normal wood grain ( no plank pattern ) but this results in a repeating pattern when alligned in a wood deck. Hope someone can help me on this one. I'm looking for good seamless woodplank textures or a way to make them myself. Maybe we can start a library here. I'm not behind my computer at this moment, but I wil post my textures that do work when I get home
Greetz Twan
Hi Pugz, a method that i use a lot and gives very good results IMHO:
-Take your wook plank texture and copy and past every single plank each in an independent file;
-Use Bricks'n'Tiles (I believe it's free for non commercial use and it's a great application) to put together your seamless texture.
It needs a bit of experience but the results worth the tries.
Here you have a cropped down example I've made in that way.
Hi Massimo,
Thanx for the Quick respons. Do you mean: select all the individual planks in a texture and save the seperately?
I've heard about the Bricks n Tiles app and I will give you method a try. Hope to post the result soon.
Greetz Twan
Yes, each plank in a different file. Then load the files in Bricks'n'Tiles.
Cool
can't wait to give it a try. It's a bit like the floor generator's that are available for 3d Max. Maybe an Idea for a new Plugin: A Floor Generator for SU
Greetz Twan
nice texture massimo
Register LoginAdvertisement
