    [REQ] K-set Tilable Surfaces
    7 Posts 4 Posters 1.1k Views 4 Watching
    • N Offline
      notareal
      http://web.mysites.ntu.edu.sg/cwfu/public/Shared%20Documents/kquad/kquad.htm
      Not sure if a plugin based on this is feasible to develop, but perhaps someone could give it a look.
      [flash=640,385:17elqil2]http://www.youtube.com/v/M6cb81vCe-w&color1=0xb1b1b1&color2=0xd0d0d0&hl=en_US&feature=player_embedded&fs=1[/flash:17elqil2]
      Also related Triangle Surfaces with Discrete Equivalence Classes http://faculty.cs.tamu.edu/schaefer/research/index.html
        Looks like a job for 'Fredo' or 'Regular Polygon' β˜€
        • P Offline
          pr0bka
          Hey guys, this is the function i was referring to when incorporating this type of effect.
          Here are some of the directions on how to do this - give the fact that Fredo's scale plugin can skew a component without editing the original. If someone could come up with a way to do this to a selected set of polygons - you could ideally make one component control a whole set of geometries.
          Here's the link :
          http://forums.sketchucation.com/viewtopic.php?f=18&t=24163 (check the last post - it shows how different polygons can use the same component). I'll also attach a copy of the sketch up file
          test_facade.skp
          • N Offline
            notareal
            Sounds similar... 😎 But that last post makes quite difference. In those papers... they try to find a groups of components (polygons) that keep the new generated form close the original. Not sure how feasible this is to your last example. But perhaps if generated components are replaced with some other with suitable tiling context.
            • P Offline
              pr0bka
              hehe, yea i know, its a bit of a cheat, but would be great to identify all the similar polygons by color (via paintbucket?) and then just make components out of each. But would it be possible to change the variations (K?):)
                Regular Polygon
                Unfortunately, I couldn't download the K-set Tilable Surfaces paper from the ACM. You either have to purchase a membership, or purchase the article. πŸ‘Ž
                The paper, Triangle Surfaces with Discrete Equivalence Classes, at http://faculty.cs.tamu.edu/schaefer/research/index.html, explained the algorithm pretty well. But it looks pretty complicated. πŸ˜’
                I think it is an interesting problem. But I wonder how often people actually need to model a surface with tiles that have exactly K distinct shapes?
                My SketchUp Plugins
                • N Offline
                  notareal
                  I have that covered... just pm. πŸ˜‰
