Set the z-coordinate of copies?
Does anyone know if it's possible to set the PosZ value for component copies using the COPY function?
You can use the
CopyandCopiesvariables in other attribute formulas.Copywill have a value from0 - Copies. So the Z position might be a formula similar to one of the following hypothetical examples:Z: =Copy Z: =Copy * 2 Z: =IF(Copy = 2, 6, 12) Z: =IF(Copies > 2, 5, 10)Is this what you meant?
Hi Jim -
Thanks for the response. I should have dug around a bit more before posting this question. Laziness, I'm afraid.
Up until now, I haven't needed to specify more than one position for copies generated using the COPIES function. I should have known, from the DC stairs I've seen, that you can specify PosX,PosY, and PosZ attributes for copies at the same time (and any other attribute, for that matter).
Register LoginAdvertisement
