    Set the z-coordinate of copies?
    Scheduled Pinned Locked Moved Dynamic Components
    3 Posts 2 Posters 1.3k Views 2 Watching
      danbig
      Does anyone know if it's possible to set the PosZ value for component copies using the COPY function?
        Jim
        You can use the Copy and Copies variables in other attribute formulas. Copy will have a value from 0 - Copies. So the Z position might be a formula similar to one of the following hypothetical examples:
        Z: =Copy Z: =Copy * 2 Z: =IF(Copy = 2, 6, 12) Z: =IF(Copies > 2, 5, 10)
        Is this what you meant?
          danbig
          Hi Jim -
          Thanks for the response. I should have dug around a bit more before posting this question. Laziness, I'm afraid.
          Up until now, I haven't needed to specify more than one position for copies generated using the COPIES function. I should have known, from the DC stairs I've seen, that you can specify PosX,PosY, and PosZ attributes for copies at the same time (and any other attribute, for that matter).
