Suddenly a "RUNTIME" error (Ver 6.1)
Yesterday I exited SU 6.1 in a normal fashion. Then I turned off the PC.
Today, even after I do a reboot, when SU starts up and is at the point of setting up the toolbars I get the following popup box.
Microsoft Visual C++ Runtime Library
Runtime error
Program:
This application has requested the Runtime to terminate it in an unusual way.
Please contact the applications support team for more information
[OK]When I click [OK] SU terminates.
Any ideas????
I would consider resetting my system to a point when everything was functioning OK.
Runtime errortry if re-installing the Microsoft VC++ 2008 SP1 Redist. Package helps.
hth,
Norbert -
hth,
NorbertThanks, but it did not work.
Gonna try reverting, if I can figure out how. It's been 3 years since I did it last.
That did work.... Big Thanks
Went back 2 days to be sure.
Register LoginAdvertisement
