    Followme on multiple line
    4 Posts 3 Posters 566 Views 3 Watching
    • N
      nics
      hi guys, here's the followme example
      point1 = Geom;;Point3d.new (0,0,0)
       point2 = Geom;;Point3d.new (0,0,100)
       depth = 100
       width = 100
       model = Sketchup.active_model
       entities = model.active_entities
       pts = []
       pts[0] = [0, 0, 0]
       pts[1] = [width, 0, 0]
       pts[2] = [width, depth, 0]
       pts[3] = [0, depth, 0]
       # Add the face to the entities in the model
       face = entities.add_face pts
       line = entities.add_line point1, point2
       begin
         status = face.followme line
       rescue
         UI.messagebox $!.message
      but I wanna continu the followme with another line connected to the first .. how do I follow on the lines (for example, one going up and then another one going right ?
      something like the attached picture
      I did something like this but sketchup told me that the face was deleted .. normal πŸ˜„
      	   endPoint = startingPoint.offset [0, 0, porte.espaceBas + porte.hauteur + porte.espaceHaut+'1/4'.to_l]
      	   lineToFollow = entities.add_line startingPoint, endPoint
                 base.followme lineToFollow
      	   endPoint2 = endPoint.offset ["1/2".to_l + porte.espaceCote*2 + porte.largeur, 0, 0]
      	   lineToFollow = entities.add_line endPoint, endPoint2
      thanks !
      • thomthomT
        Error 404 (Not Found)!!1
        (code.google.com)
        The followme method is used creating a shape by making the face follow along an array of edges.
        While the Arguments just says "An Edge object to follow." the description seem to indicate you can feed the method an array of edges.
        • TIGT
          As the 'face' is lost after any FollowMe then make an array of all of the edges to follow and do it once using them πŸ’­
          • N
            nics
            haha yeah I was looking at the argument !
            Arguments:
            edge1 An Edge object to follow.
            I like java for having api doc clearer πŸ˜„ Ill read the description too in the future.
            thanks !
